![]() | Home > Puma (Tdci) > 110 rear springs |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Evening all. While I was under my defender today (fitting an uprated rear anti roll bar) I noticed a plastic spacer in between the top two coils of the rear springs. Any ideas what they do? Thanks in advance
![]() Ps. Forgot to take pictures 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Most likely vibration dampening rings.
I fitted some to mine a while back ![]() ![]() Click image to enlarge Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Do they do the same job as the rubber spring isolators? 2002 90 Td5 Station Wagon
Another name for the same thing.
On 90's you can use the ones for the front on the rear as the rear springs on a 90 are the same size as the fronts. They are like a castellated rubber ring with a metal inner which slots inside the top of the spring. On a 110 or 130 the rear springs are heaver duty and wider so they cant use the front isolators which in my opinion are slightly better. They are more like a rubber sleeve which clips over the top of the spring. The difference it makes is only marginal, but still worth doing. ![]() Click image to enlarge Front 90/110/130 and rear 90 Left Rear 110/130 Right. Hope that helps ![]() Self confessed mileage hunter ![]() |
If there big thick rubber bits wound in to coil there spring helpers / asisters
like this eBay Item No. 251902704604 |
It's definitely a factory item. I'll have to have a closer look tomorrow as I'm not sure it sits on the top of the spring more like the second coil down. I'll report back with my finding
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
