Home > Puma (Tdci) > 110 rear springs
grafty99
110 rear springs
Evening all. While I was under my defender today (fitting an uprated rear anti roll bar) I noticed a plastic spacer in between the top two coils of the rear springs. Any ideas what they do? Thanks in advance Thumbs Up
Ps. Forgot to take pictures 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #415516 11th Apr 2015 8:18pm
shaggydog
Most likely vibration dampening rings.
I fitted some to mine a while back Thumbs Up
 Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #415518 11th Apr 2015 8:23pm
grafty99
Do they do the same job as the rubber spring isolators? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #415522 11th Apr 2015 8:29pm
shaggydog
Another name for the same thing.
On 90's you can use the ones for the front on the rear as the rear springs on a 90 are the same size as the fronts. They are like a castellated rubber ring with a metal inner which slots inside the top of the spring.
On a 110 or 130 the rear springs are heaver duty and wider so they cant use the front isolators which in my opinion are slightly better. They are more like a rubber sleeve which clips over the top of the spring.
The difference it makes is only marginal, but still worth doing.
Front 90/110/130 and rear 90 Left
Rear 110/130 Right.
Hope that helps Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #415534 11th Apr 2015 8:45pm
munch90
If there big thick rubber bits wound in to coil there spring helpers / asisters
like this
eBay Item No. 251902704604
Post #415537 11th Apr 2015 8:52pm
grafty99
It's definitely a factory item. I'll have to have a closer look tomorrow as I'm not sure it sits on the top of the spring more like the second coil down. I'll report back with my finding Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #415584 11th Apr 2015 10:33pm
