Home > Td5 > Turbo pipe oil leak
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Turbo pipe oil leak
Hi all, discovered a new smell on the way home today Crying or Very sad
Seems / looks like the metal pipe from the bottom of the turbo is leaking ,
Is this a common issue ?
Is there a simple fix ?
Kinda hoping ( or wishing ) it's a o ring or gasket between the two surfaces Confused
Thanks in advance chaps n chappesses
Post #413291 2nd Apr 2015 8:23pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Small paper gasket.
Only two 10mm bolts, fiddly Censored to reach though Guns and Landrovers .... anything else is irrelevant.
Post #413301 2nd Apr 2015 8:46pm
Fatboy Slim
Wales
You need 1x PNT100030 gasket. Easy job. Half hour tops.
Post #413307 2nd Apr 2015 8:56pm
NickMc
Check the pipe as they can delaminate and starve the turbo.
Post #413661 4th Apr 2015 1:05am
Daisy90
All done today, simple enough although a bit tight if ya have stumpy digits perhaps,
What was interesting was apparently the original ones were a paper type gasket, now replaced with a metal one,
For the cost of �2.75 I used a genuine one
When I took mine apart I couldn't find any evidence of any gasket at all ?!
Scraped with a Stanley blade and everything, perhaps that's was why it was leaking :0)
Thanks for ya helps chaps
Post #415121 9th Apr 2015 10:05pm
