![]() | Home > Td5 > Turbo pipe oil leak |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Small paper gasket.
Only two 10mm bolts, fiddly ![]() |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
You need 1x PNT100030 gasket. Easy job. Half hour tops.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
Check the pipe as they can delaminate and starve the turbo.
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
All done today, simple enough although a bit tight if ya have stumpy digits perhaps,
What was interesting was apparently the original ones were a paper type gasket, now replaced with a metal one, For the cost of £2.75 I used a genuine one When I took mine apart I couldn't find any evidence of any gasket at all ?! Scraped with a Stanley blade and everything, perhaps that's was why it was leaking :0) Thanks for ya helps chaps |
