Home > Technical > Air Conditioning Query
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
My 07 Defender is back at the dealers for a second attempt at fixing the A/C. The problem is to do with the thermo-switch which fails to cut out when cooling down. The core drops right down to freezing and consequently the heat exchanger ices up and very little air flows through (at least that's how I understand it). I noticed this about a month after I took delivery and the dealer fixed it. Things seemed to work fine for a couple of months then, after a few warm days I noticed it doing the same thing again.
It has been back at the shop since last Tuesday. The dealer informed me that they had a second vehicle doing the same thing AGAIN so they sent a technical query off to Land Rover Australia. They subsequently escalated the issue to Land Rover UK. The response came back to replace the exact same bit (thermo-switch) that was replaced last time.
Now I don't hold out much hope for this fix actually working and with the weather cooling down here it will most likely be October before I really know whether or not it's fixed. Logic would dictate that if you fixed something one way (on more than one vehicle) and it stops working again on both, then maybe there is something else awry.
Is there anyone else here who has had the same issue with their new Defender's A/C? I know most of you guys have just been through winter and don't get many 40degree days, but I thought I'd ask the question. I guess I'm just fishing to see if this is a known design fault, or I and the other guy just got our dodgy switches replaced with ANOTHER bad batch of switches. 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #2134 17th May 2008 1:37am
solmanic
The A/C is supposedly all fixed and seems to be working. I'll wait and see if the problem re-occurs after a month or so. 2007 Defender 110
Post #2207 28th May 2008 11:47pm
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
Cool Thumbs Up
Was the switch replaced again or was it something else? Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #2208 29th May 2008 3:12am
TJ101
Re: Air Conditioning Query
Mines been OK,, (so far) ran permanently for 3 weeks, beginning of the month round Portugal/Spain etc California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #2211 29th May 2008 9:02am
solmanic
This is my point - they just replaced the SAME switch that was replaced in February. After escalating the issue to Land Rover UK, they just came back with the instruction for the dealer to repeat the last repair again. Hence my concern that the problem may lie with some other component and the thermal cutout switch failing is merely a symptom. I will wait and see how things go. 2007 Defender 110
Post #2236 30th May 2008 3:59am
thornbma
Hey, guys, just think of a domestic AC unit, and don’t get distracted by it being in a vehicle. A domestic unit will freeze up, and lose cooling efficiency, when it loses gas. This results in a lower pressure in the high pressure side, resulting in a lower boiling point of the refrigerant. At design pressure the boiling point is above 0 deg. C, hence plenty of condensation on the cooling coils, but no ice. As the gas leaks, slowly, the discharge pressure drops, and the boiling point of the refrigerant drops. We all know about trying to make a decent cup of tea, or boil eggs, at high altitude – the water boils at a much lower temperature, and you end up with maiden’s bath water or runny eggs. The same thing happens with the AC refrigerant, it boils at a much lower temperature. There was almost certainly nothing wrong with either switch, the problem was a slow – very slow – leak of gas.
Post #4150 5th Oct 2008 2:38pm
shorty
South Africa 2009 Defender 90 Puma 2.4 XS CSW Chawton White
Hey guys, I was driving my defender from Johannesburg to the Kalahari via the Karoo last week Temp was 42 deg c and my aircon was playing up. When you initially turn it on it pumps with cold air but after 10 minutes the air flow begins to decrease and eventually there is zero airflow. If I turn the aircon off for 15 minutes and turn it back on again it works fine for the next 10 min. My problem sounds exactly like yours solmanic. Land Rover's don't leak oil, they simply mark their territory!
Post #8385 13th Mar 2009 8:17am
110SEB
I have some faith in technical queries sent off to someone at LR. We had a problem with our ECU taking over with the central locking. When we all got out of the 110, closed the doors behind us and went to rummage in the boot, the central locking would lock the car after about 20 seconds. Since the boot was open the horn would honk-honk as it does when doors aren't properly closed at lock down.
On 3 separate visits to the dealers they said first, that we were pressing the key fob in our pockets, then, that we were either doing that but they certainly couldn't find fault, and then thirdly they acknowledged the fault and sent of a tech query which told them to reprogram the central locking on the ECU.
Problem solved for good.
Perhaps in the case of the A/C problem, the part in question has changed manufacturer or been revised? Perhaps a bad batch of parts in the old swap over and this time it'll be alright. Fingers crossed. How awful it must be to have to suffer hot weather and blue skies all the time. I really feel for you. Only the British would send all their convicts from a damp cold island to the largest desert island in the world with sandy beaches, space, sun and a whopping LR playground.
Post #8386 13th Mar 2009 9:29am
solmanic
Yep, that is exactly the same problem. The core is icing up and blocking airflow so all you get is an asthmatic wheeze of mildly cool air.
Mine seems to be all fixed now and has made it through summer with much more effectiveness than last year. I still got them to check it over at the last service and they confirmed that everything was operating within spec. I think I seriously need to consider tinting the windows to make things any better. 2007 Defender 110
Post #8460 16th Mar 2009 2:36am
solmanic
When you raise a sweat just towelling off after a cold shower you realise there are limits to how hot you are prepared to tolerate for days on end. Sorry, but give me cold weather anytime. At least you can keep putting stuff on to warm up, but if it's hot and you're nearly naked with no breeze, then all you can do is stand there and feel uncomfortable.
Even when it's working perfectly, it is pretty clear that the Defender's A/C was never designed for tropical climates. And on the flipside, the heater output is positively nuclear! 2007 Defender 110
Post #8461 16th Mar 2009 2:42am
mse
im with you - i cant stand the heat...not looking forward to summer Mike
Post #8492 16th Mar 2009 5:29pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Mine has just stopped working alltogether, push the button, blower starts but it doesn't blow cold air, another thiong to add to the list when its in next week.
Post #8495 16th Mar 2009 5:54pm
discocuzzy
Used my aircon today....window open and defender elbow resumed...oooh amd i opened my little vent flaps but then again i only have an old Xreg TD5 Big Cry You cannot teach stupid people to do clever things
Post #8550 17th Mar 2009 7:32pm
CapeLandy
South Africa
My aircon works but at 43'C outside it really struggles to keep the gearbox and us all cool.
The heat from the tunnel and floorboards is too uncomfortable even to drive bearfeet.
My series 3 also does that so I'm not too worried. Puma 110 - gone
Series III 1973 - going strong
Post #8663 20th Mar 2009 5:34pm
AndrewS
Has anyone had the stream of misty icy air coming from the top vents Question
Post #8666 20th Mar 2009 5:50pm
