Home > Technical > Help please 2004 td5 bulkhead with abs an traction control l
D922MAT
United Kingdom 2004 Defender 110 Td5 XS DCPU Loire Blue
Hi guys I need so help. I brought a bulkhead with a xs td5 loom as standard. I need to remove the abs wiring from the loom Or take out the pins which feed the power to you abs unit. I have fitted the bulkhead to my 110 build an I know have power going to the loom. Does any Ono on here know which wires to discount the abs so the lights don't come up on the dash. I've also noticed the abs light also keeps the hand break light on. I need the loom to run my electric windows an heated front screen. An the normal hand break switch. I would fit abs to vehicle but I am running out of money to keep throwing at it. It would be great if sum Ono would be able to advise
Thanks Matthew
Post #409121 19th Mar 2015 11:05pm
jimbob7
As far as I know (not 100% sure),there are 2 resistors fitted inline on the handbrake/low fluid AND ABS dashboard warning lights on NON-ABS fitted vehicles,so if you use your old non-ABS instrument panel I think you just have to leave the abs connections,er, un-connected,as you have no abs pump or ecu,this won't be difficult.
diagram 47 (Instruments) on td5 wiring diagram.
http://www.landroverweb.com/Pdf-files/Defe...iagram.pdf
Let me know how it goes. Pov.spec,ftw. 2006, 110,TD5.
Post #409244 20th Mar 2015 1:33pm
landyman37
Can you not just remove the wire. From the back of the dash light
Post #414165 6th Apr 2015 12:23pm
dailysleaze
You have to add extra wiring to one of the warning light plugs, so that the wiring loops back on itself a couple of times
http://www.landroverexpedition.com/technic...ng-lights/
Post #414593 7th Apr 2015 9:28pm
