Home > Technical > Help please 2004 td5 bulkhead with abs an traction control l |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
As far as I know (not 100% sure),there are 2 resistors fitted inline on the handbrake/low fluid AND ABS dashboard warning lights on NON-ABS fitted vehicles,so if you use your old non-ABS instrument panel I think you just have to leave the abs connections,er, un-connected,as you have no abs pump or ecu,this won't be difficult.
diagram 47 (Instruments) on td5 wiring diagram. http://www.landroverweb.com/Pdf-files/Defe...iagram.pdf Let me know how it goes. Pov.spec,ftw. 2006, 110,TD5. |
20th Mar 2015 1:33pm |
landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 153 |
Can you not just remove the wire. From the back of the dash light
6th Apr 2015 12:23pm |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
You have to add extra wiring to one of the warning light plugs, so that the wiring loops back on itself a couple of times
http://www.landroverexpedition.com/technic...ng-lights/ |
7th Apr 2015 9:28pm |
