Home > Puma (Tdci) > Clutch change workshop manual needed. |
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 193 |
As title
I need the workshop manual with torques etc to do the clutch. also if anyone knows the dimensions of the clutch alignment tool too. TIA Wil |
6th Apr 2015 3:18pm |
Hopefully this will work. Whilst the MY07 on is a complete manual the MY12 on isn't.
https://onedrive.live.com/?cid=4bc2d89c85c...171%217067 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Apr 2015 3:33pm |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 |
If you use the search function you will find a number of posts with the information you require.
The 2.2 workshop manual can be found at http://www.defender2.net/forum/topic20997.html |
Same link as mine but 2.2 Workshop doesn't appear to go beyond the index. It may be me though. Have a route about. The 2.4 manual is complete. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Apr 2015 3:38pm |
Was my impatience and the fact my 'interestommeter' wasn't that high owning a 2.4.... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Apr 2015 4:11pm |
Thanks for that. My internet went down shortly afterwords so only now being able to use it.
16th Apr 2015 7:27am |
