Home > Puma (Tdci) > Clutch change workshop manual needed.
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
As title
I need the workshop manual with torques etc to do the clutch.
also if anyone knows the dimensions of the clutch alignment tool too.
TIA
Wil
Post #414198 6th Apr 2015 3:18pm
K9F
Hopefully this will work. Whilst the MY07 on is a complete manual the MY12 on isn't.
https://onedrive.live.com/?cid=4bc2d89c85c...171%217067 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #414200 6th Apr 2015 3:33pm
driver9
If you use the search function you will find a number of posts with the information you require.
The 2.2 workshop manual can be found at http://www.defender2.net/forum/topic20997.html
Post #414201 6th Apr 2015 3:33pm
K9F
Same link as mine but 2.2 Workshop doesn't appear to go beyond the index. It may be me though. Have a route about. The 2.4 manual is complete.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #414204 6th Apr 2015 3:38pm
driver9
Just checked the link I posted the full manual appears to be there although it does only show the first couple of index pages to start with. It took a few minutes for the full download to appear using my rural slowband.
Post #414209 6th Apr 2015 3:54pm
K9F
Thumbs Up
Was my impatience and the fact my 'interestommeter' wasn't that high owning a 2.4.... Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #414214 6th Apr 2015 4:11pm
willyj
Thanks for that. My internet went down shortly afterwords so only now being able to use it.
Thumbs Up
Post #416548 16th Apr 2015 7:27am
