Home > Technical > Puma taper negative battery terminal
DAZ110
Does anyone know of a way to connect addition wires to the original taper negative battery terminal connection clamp on the puma?... without chopping off the original terminal and replacing it.
Post #41281 25th Sep 2010 4:13pm
AndrewS
I looked into this and ended up cutting the original one off and replacing it. 130's have feeling's as well you know Smile
Post #41324 26th Sep 2010 1:03pm
DAZ110
Ok, thanks AndrewS.
I thought this would the case.
What did you use instead?
Post #41336 26th Sep 2010 5:56pm
leeds
We use these stud type terminals
Much easier to connect cables to it.
HTH
Brendan
Post #41618 30th Sep 2010 8:06am
DAZ110
Thanks mate. Looks like just what I need.
Post #41620 30th Sep 2010 8:28am
