Home > Off Topic > Welder
mse
Welder
Im after a recommendation for a welder.
Nothing too fancy, just something to get me started and to play/learn
Any ideas? Mike
Post #41075 22nd Sep 2010 5:24pm
AndrewS
What type of welding do you want to do?, ie what things do you want to weld?
How thick ?
New stuff or old stuff?
Ally or steel or both? 130's have feeling's as well you know Smile
Post #41082 22nd Sep 2010 6:12pm
jst
i started with a small gas bottled mig 150A from machine mart which was fine for me to get going. i have recently upgraded to a SIP one (cant remember the number) and an auto darkening lens. a decent lens/headgear system is def worth the money, even even only a hooded one over a std hold op one. at least you have both hands free then. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #41083 22nd Sep 2010 6:13pm
mse
Being a pilot im a little picky over my eyes - so great advice!
As for welding - obviously to me steel, I wasnt really thinking "fix a chassis" level yet, but i suppose that would be the max i would get to.
At the minute its about practicing joining and getting used to making one bit of metal 2
Does that make any sense Mike
Post #41151 23rd Sep 2010 3:47pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Get the best you can afford....Don't get less than a 150 ...go on youtube to give you a few ideas of how the things work... there's some good vids on there Thumbs Up
As stated before machine mart have a few the first one i had was a sealey 150 good starter machine NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41165 23rd Sep 2010 5:35pm
mse
Thanks - i shall go and look.
Whats the view on Gas or no gas Mike
Post #41166 23rd Sep 2010 5:57pm
fekete
Gas Mike you get a better weld Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41167 23rd Sep 2010 6:00pm
mse
Gas it is then Mike
Post #41172 23rd Sep 2010 6:43pm
mse
Sorry for the stupid question...looking at the MIG welders, i also noticed the Arc welders - should i avoid given the comments about welding is better with gas etc?
Or is it a cheap way into the field of welding Mike
Post #41199 24th Sep 2010 7:17am
fekete
Mike arc welding you don't use gas... but if your going for a mig then gas is the best option Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41200 24th Sep 2010 7:24am
mse
Got you, thanks, I was wondering if arc was easier than mig the arc welder i was looking at is £80 and the mig of the same 150amp is £270 - i assumed MIG is better, but with no welding knowledge (other than its a skill!) I have no idea Whistle Mike
Post #41201 24th Sep 2010 7:26am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
mse
I bought a 150 Sealey mig 6mts ago as I need to do some work on the rear cross member on the 90. I had not welded since the early days of being in the army so wanted to read up on it and practise a bit to avoid pigeon poo and subsequent micky taking from others.
I found this site a real gem.
http://www.mig-welding.co.uk/
HTH
Boy
Post #41202 24th Sep 2010 7:38am
fekete
First off Arc welding is done on thicker metals, plate and piping, not very pretty, used mostly for speed. Mig uses gas to shield giving you cleaner welds, no slag to chip off. Can weld a wider range of thickness of metals. Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41203 24th Sep 2010 7:39am
mse
Thanks both
MIG it is then Thumbs Up if im going to do it, may as well do it right and be able to do a reasonable job at it.
Great website - ill have to set some time to go through and certainly save it.
thanks again Mike
Post #41204 24th Sep 2010 7:41am
fekete
Mike when you get one just practice doing straight lines on a piece of steel don't try getting two metals to stick....it takes time and you can become frustrated....also it's all about penetration you need to get the metal to melt....when i was learning Tig welding that's how we learnt lots of straight lines...Good look mate Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41205 24th Sep 2010 7:58am
