![]() | Home > Maintenance & Modifications > Nakatanenga Antenna? |
Just got a newsletter advertising the Nakatanenga (Hirschmann) antenna. Has anyone had experience with one?
My standard telescopic LR one is okay but has been knackered twice (once through vandalism), so I'm considering an upgrade. For 90 Euros, though, it has to be worth it... Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
farnley Member Since: 13 Jan 2013 Location: Dusseldorf Posts: 30 ![]() ![]() |
also got the mail and looking at with interest , so let me know ZeDefender if you take the plunge
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3791 ![]() ![]() ![]() |
What do these look like?
Pickles. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
I got it too, some interesting products there.
Some of them I've known about for a while. ![]() |
![]() Click image to enlarge ![]() |
Cheers Brendan. I knew they'd be tough, it was good reception I was concerned about (I've had bad experiences before). Thanks for the info - looks like another Defender purchase is due ![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
Do you stock these Brendan?
![]() I forgot to include them ![]() We have another delivery next week so will see if I can get them included in that order. We get regular deliveries from Nakatanenga, so if it is on their websites we can supply it. Brendan |
I just ordered one so I'll give feedback in a few days
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1314 ![]() ![]() ![]() |
Is the Nak aerial amplified?
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 262 ![]() ![]() ![]() |
I don't think the Nakatanenga (Hirschmann) antenna in the advert has integrated booster.
Have a look at the Blaupunkt 7 617 495 224 Autoflex aerial, it's a Universal, short-style wing mount aerial with integrated booster amplifier for AM/FM raido. http://www.bluespot.co.uk/car-audio.aspx/7617495224-aerial http://www.blaupunktdirect.co.uk/antennas-...erial.html http://www.blaupunktdirect.co.uk/antennas-aerials.html?subcats=Y |
the bosch autoflex is the one I used , seems good
but the hole in the wing is too big to direct fit , but I used part of the standard aerial base and fitted ok and you need 12v feed for built-in booster |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5117 ![]() ![]() ![]() |
Nakatanenga Hirschmann radio antenna for Land Rover Defender ruggedness for off-road use We use a proven Hirschmann antenna and produce a multi-part stainless steel and aluminium mounting to fit into the original mounting hole in the Land Rover Defender, Specifications: antenna length: 47, 5 cm cable length: 133 cm material antenna: glass fibre, black material base: stainless steel and aluminum frequency range: 0.15-6.2 MHz / FM 87,5-108 MHz the visible part of the holder is in stainless steel .
Hirschmann radio antennas are a great brand and I am sure that Nakatanenga do a great job with their multi-part stainless steel and aluminium mounting and at £67.50 is probably good value. However if you wish to make your own mount the aerial whip can be found here complete with 1330mm low loss cable to DIN plug. http://www.ebay.co.uk/itm/HIRSCHMANN-HIT-A...259e3f5078 ![]() For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 Last edited by gilarion on 28th Mar 2015 1:58pm. Edited 2 times in total |
I've had a fair amount of success from this if you're on a budget http://www.ebay.co.uk/itm/Amplified-Replac...0559708597
But I've just noticed that this particuar one is "out of stock" at the moment |
