Home > Tdi > Wiring diagram 1993 90, 200TDi |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
From memory the purple is a permanent +12V and the white is an ignition switched +12V
22nd Mar 2015 7:01pm |
Gazngoz Member Since: 17 Mar 2015 Location: Worcs Posts: 23 |
Excellent thanks. Multi-meter confirms purple is permanent +12v. There's an awful lot of brown wires back there - anyone any idea on those please ?
22nd Mar 2015 8:15pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Brown is live from battery un-fused/switched from memory but not necessarily plugged in at the other end to anything.
200Tdi's never had Iso plugs from new so you would have to wire them in yourself. If you can hang on till tomorrow I can have a look at mine and send a proper photo of how mine is wired I have a similar wireing behind mine- yet to find a use for it! Click image to enlarge Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
22nd Mar 2015 8:42pm |
Shaggydog,
That would be great thanks for your time Gaz |
22nd Mar 2015 9:40pm |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 |
Lots of wiring on the engine side of the bulkhead I noticed wonder what they had in mind?
23rd Mar 2015 12:06pm |
Here are the photos, Hope they help somewhat!
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge With regards the extra plugs and wires, I seem to remember reading somewhere that the 200Tdi loom was a modified TD loom so has lots of plugs and bits left over from when it was just a TD. These then got cleaned up and away with the 300Tdi as well as better plugs and more dedicated looms. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
23rd Mar 2015 6:57pm |
Shaggydog,
Superb mate thanks. The more I look at my loom the more credible the ex-TD loom sounds Think I'm going to split the "plug" containing the permanent and switched +12v that I think was for the original radio and use those feeds for my clock and possibly later a stereo. Don't have all the wires you have shown there. Thanks again for your help. G |
23rd Mar 2015 8:54pm |
Shaggy,
On your pics above you have cig lighter on LHS, what I assume is a clock in the middle but what is it in the RHS position ? Got some sound deadening in and the dash lower - just got to sort out the wiring. Touch wood, looking good ! Thanks for your help Gaz |
17th Aug 2015 7:16am |
Yes you are correct
Cigar lighter, Clock, Rear Wash Wiper (if fitted) You will have to stick some photos up as it sounds like its coming on well Hope it helps Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
17th Aug 2015 11:33am |
