Home > Puma (Tdci) > Ticking Noise
Page 1 of 3 123>
CatherineF
Ticking Noise
Fired her up today and it's developed a metallic sounding ticking noise, which you can hear from inside the truck as well as outside in addition to the normal Puma engine sounds.
I think it's coming from the underside and it doesn't appear to change with engine speed. It's no better or worse when warm/cold. When moving you can't hear it, it's only audible at idle/low engine speeds. At one point after a blast down an A Road I thought it had gone but it hasn't.
Any thoughts? I'm sorry I can't be any more specific. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #409891 22nd Mar 2015 1:55pm
Could you take a sound clip?
Post #409894 22nd Mar 2015 2:02pm
CatherineF
Will go and record one, how do I post it here? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #409899 22nd Mar 2015 2:10pm
Good question, YouTube link maybe?
Post #409902 22nd Mar 2015 2:25pm
CatherineF
Had a look at that but it's audio only so doesn't want to let me do it.
I've got a great sound clip though. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #409903 22nd Mar 2015 2:27pm
CatherineF
Post #409911 22nd Mar 2015 3:33pm
Green Machine
Well it's definitely engine speed related because it gets noticeably faster with that little blip of throttle at the end of your clip. Sounds like something in the engine bay is loose. Engine lift bracket was the first thing that jumped to mind. Presumably you have already opened the bonnet with the engine running and looked / listened for anything that is rattling or loose? 2005 Td5 | 90 Station Wagon | Tonga Green
Post #409912 22nd Mar 2015 3:43pm
CatherineF
It's also interesting that it was serviced just over a week ago and today is the 1st time I've driven it since it came back. Hubby hadn't noticed it but my hearing is a lot more sensitive than his. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #409914 22nd Mar 2015 3:45pm
CatherineF
Not sure if this will give any more clues.
There is nothing loose when you lift the bonnet and when you look under the bonnet with the engine running you can't hear it.
You start to notice it when you are stood by the drivers front wheel and really notice it when you are alongside the drivers door
The recording I made was with the iPhone held underneath the drivers footwell. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #409916 22nd Mar 2015 3:52pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Had anything done to the clutch at all? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #409919 22nd Mar 2015 4:08pm
CatherineF
No it had an A service and a general inspection. Depressing the clutch doesn't have any impact on the noise either if that helps? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #409921 22nd Mar 2015 4:11pm
Sounds a little like something thin and metallic.
Possibly a heat shield loose, or similar metal part.
Sounds a little like it increases with revs / vibration.
I'd hazard a bet something has been touched during servicing time, I had an issue with earthing. After the clutch change.
I don't think it's any EGR issue as it sounds too loud for that and it's on the OS engine bay too.
Cannot be the drivetrain as its stationary and it doesn't sound internal I.e. Clutch / pressure plate / flywheel.
Possibly turbo heat shield?
Post #409923 22nd Mar 2015 4:17pm
ian series 1
I would have a proper good look under and around the serpentine belt and all the ancillaries to start with, 80" 80" 86" 88" 90"
Post #409926 22nd Mar 2015 4:23pm
ian series 1
I have known the heat shield that sits on the flywheel sensor make strange noises before,
They are only held in the bell housing with 2 metal clips, and can rattle a lot
Question 80" 80" 86" 88" 90"
Post #409928 22nd Mar 2015 4:26pm
munch90
I wouldn't say it was a rattle made by something loose , normally rattles that are there on tickover go a bit as revved or at least change sound
always going to be hard to say on a recording , it sounds metallic , but slight blow on one exhaust manifold port ???
almost sounds on one cyl , tappet noise ?
hydraulic tappet with air in it , but after you saying its had a run I would have expected it to clear
Post #409929 22nd Mar 2015 4:29pm
Page 1 of 3 123>
