Home > Puma (Tdci) > Ticking Noise
Page 3 of 3 <123
landy andy
I would remove heat shield from around turbo, and check for failed gasket between turbo and manifold. Mine was.
Andy
Post #410075 22nd Mar 2015 10:59pm
CatherineF
So ours is the same age as Andys. It's done around 8,000 miles less. Hubby is ringing the garage at 9 to see if he can pop it into them this afternoon. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #410090 23rd Mar 2015 7:08am
CLCraig
United Kingdom 2015 Defender 90 Puma 2.2 HT Stornoway Grey
Let us know what it ends up being. Hope it's nothing serious for you Thumbs Up
Post #410093 23rd Mar 2015 7:24am
CatherineF
Well it appears to be a flexible joint on the exhaust that is loose. It's going in on Wednesday afternoon for new pads, diff seal and this so hopefully all will be back to normal. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #410267 23rd Mar 2015 6:39pm
Think I know the section, question is, why?
Someone knows why it is loose all of a sudden. Whistle
Post #410271 23rd Mar 2015 6:57pm
munch90
by listenning to recording , i would not have said that was a exhaust blow , but always hard to tell like that
the flexi is in front pipe , along with cat
might be worth checking price before you give go ahead ,
as might be worth going for second hand one
Post #410272 23rd Mar 2015 7:05pm
CatherineF
So she's been in the workshop today.
Has new brakes all around and the rear diff seal has been sorted. Total cost came to just under £250 inc VAT.
With reference to the ticking noise, once on the ramp they have concluded there is nothing externally obvious. It appears that on closer inspection it's coming from the Bell Housing/Clutch and that it is the springs chattering. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #410893 25th Mar 2015 7:16pm
Page 3 of 3 <123
