Home > Technical > Indicator problems (x2)
leeds
(1) 09 Utility wagon, have been towing with it recently. Now without a trailer attached the trailer indicator light flashes when you indicate.
Any ideas folks?
(2) 96 110 CSW. When towing to get trailer indicator to flash left have to put pressure downwards on indicator stalk, seems to work then. Turn right lifting indicator stalk to top seems to work but more hit and miss. Works fine without a trailer
Time for a new indicator stalk??
Brendan
Post #40982 21st Sep 2010 8:11am
BigRuss
Sounds like it's either the switch or a loose wire.
But I bet you can't buy the switch without the stalk!
Post #40983 21st Sep 2010 8:14am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Re: Indicator problems (x2)
Any ideas folks?
Here, the trailer light comes up briefly when indicating, it does not flash though. It's been like that with both Defenders I owned so I deemed it as "normal".
Post #40984 21st Sep 2010 8:17am
leeds
Think know the solution to (1)
ARB winch bumper fitted which has repeater indicators on! Dooohhhhhhh! Banging Head Banging Head Banging Head
I will never make a mechanic!
Brendan
Post #40985 21st Sep 2010 8:23am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
As for (1) the trailer indicator flashes once if nothing is connected to the trailer socket (whether fitted or not). If you fit a bullbar with indicators it adds an extra bulb to the indicator circuit, just like connecting a trailer does. The flasher circuit detects this extra current and this causes the trailer lamp to flash as well to tell you the trailer indicator is working.
Two easy solutions: (a) replace the bulbs with 5W ones in the bullbar or (b) put LED bulbs in the bullbar indicators. This will stop it happening.
Of course the other thing that happens is that if you attach a trailer with LED lamps the trailer indicator doesn't flash for the same reasons as above.
As for (2) no idea Confused 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #40987 21st Sep 2010 8:38am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Sounds like the switch on issue 2.
The switch/stalk sets are on ebay all the time, i think you have to remove the steering wheel and set up the automatic off function when re fitting the new one.
Its simple, just set the blue dial to the centre before refitting the steering wheel.
Post #40990 21st Sep 2010 10:57am
expedition
Italy 2007 Defender 110 Puma 2.4 SW Keswick Green
I purposely removed the blue circle that leads back to the arrows in his place, I feel very good. Smile Vale
110 Td4 MY07 "E" Keswick Green
Post #40993 21st Sep 2010 11:22am
