Home > Puma (Tdci) > blue smoke |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
Firstly is your Landy still under warrenty with the dealer? Also in the colder weather (early mornings) exhaust emissions do tend to show more under colder temperatures. Other than that it maybe that theres a slight overfill of engine oil? If it's none of these then it probably needs to be checked out. Even mine which is in perfect order (touch wood) does smoke on a early morning under cold temperatures when the engine starts from cold. Someone else should be along soon to perhaps ive some more technical explanations.
20th Sep 2010 10:34am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2445 |
Unlikely defective valve rubber seals but also could be a leaking turbo. You can check if you get oil on the intake manifold. Puma 110" SW
20th Sep 2010 12:31pm |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 |
just had a look under my 90 to see if i could locate the transsmission noise and most is coming from a new clutch recently fitted and also the front diff also whilst under there i noticed the rear diff is leaking bad and also the transfer box off into stratstone in the morning me thinks
23rd Sep 2010 6:29pm |
