Home > Puma (Tdci) > Recall - Wheel Hub
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Recall - Wheel Hub
Had a phone call from the stealers service dept yesterday for a warranty recall. She couldnt really give me too much detail over the phone but has sent the below through in an email
During ongoing quality assessment of our product it has been identified that a possible safety related defect may be present on certain Land Rover vehicles within a specific production range. Please read the information below, this will explain the actions that we intend to take and what you will need to do;
Reason for this programme
Jaguar Land Rover has received through its Global Concern Management (GCM) system reports that indicate customers have experienced a loud noise, followed by severe vehicle vibration and wheel lock up.
Upon investigation it was identified that certain fixings used in the front and rear hub assemblies on Defender vehicles may have overly brittle bolts installed. Should brittle bolts be present, there is a risk that in service they could fracture. Due to the enclosed condition of the hub assembly a fractured bolt could cause secondary damage to other bolts and components. In the case of the front brakes, the broken fixings could puncture the front brake disc, leading to loss of structural integrity and the brake disc could fracture. Furthermore, the fixings that secure the hub fixings to the axle may be damaged to the extent where the hub is no longer fully secured to the axle.
In this condition, if extreme braking occurs, the anti-lock braking system will not compensate for the braking imbalance and vehicle stability will be compromised.
Wheel lock up or braking instability could significantly increase the risk of a crash.
What Jaguar Land Rover Limited and your Land Rover authorised repairer will do
At your visit, your preferred Land Rover authorised repairer will replace all the specific bolts within wheel hub assembly. This will be completed on both front and rear wheels. If damage is observed the retailer will replace all associated components.
How long will it take?
The work on your vehicle will be carried out as quickly and efficiently as possible in order to minimise inconvenience to you and will take approximately five hours to complete. However, due to your Land Rover authorised repairer schedules, your vehicle may be required for longer.
If you have concerns
If you experience any concerns relating to this Voluntary Recall, please contact the Service Manager at your authorised repairer for assistance or contact the Jaguar Land Rover Limited Customer Relationship Centre on 0370 5000 500
This Recall Action is being undertaken in accordance with the legislative or industry requirements concerning vehicle defects. The authorities will closely monitor the response rate of this Recall Action.
Please treat this matter with the urgency it requires. Jaguar Land Rover Limited apologises for any inconvenience this Voluntary Recall may cause and thank you, in advance, for your co-operation.
Anyone else had similar?
Rosco 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #409031 19th Mar 2015 6:02pm
grizz
2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Was it for your 2014 110 ?
Post #409047 19th Mar 2015 7:21pm
Rosco
Yes Grizz 2007 - Stornoway Grey 90 XS SW - Gone
Post #409054 19th Mar 2015 7:46pm
CLCraig
United Kingdom 2015 Defender 90 Puma 2.2 HT Stornoway Grey
Any ideas on which production numbers are affected?
Post #409059 19th Mar 2015 7:57pm
GUM97
This recall, P053 affects vehicles built between 24/10/2014 to 04/12/2014.
Vin Range: LD461900 - LD464300
Any questions ask away Thumbs Up
Pete An engine to TDi for!
Post #409062 19th Mar 2015 8:04pm
CLCraig
Ok thank you mine was September 14 but will check the VIN to be sure.
Post #409064 19th Mar 2015 8:09pm
grizz
Phew .. Mines July
Post #409074 19th Mar 2015 9:06pm
uncas
A friend had the same problem on a 300 tdi Disco front wheel locked up and a broken stid punched through the hub. Good job he was only driving slowly as he had just pulled out of the yard at work.
Uncas
Post #409090 19th Mar 2015 9:51pm
ATW
Singapore 2014 Defender 110 Puma 2.2 HT Indus Silver
Hi Guys,
I am from Singapore and i just took delivery of my defender 110 hard top.
It's been less than 2 weeks and my defender is in the workshop.. and i just came across this article. I have experienced the front left wheel a loud noise from the front undercarriage and my front wheel being locked and much vibrations when driving.
not sure if my defender is in the list. but its made in november 2014...
my vin is SALLDHNP7FA463016
Is it possible to assist me to check if i am on the "lucky list" please?
Post #433642 25th Jun 2015 8:02pm
GUM97
^^Yes, yours is in the range for the recall! An engine to TDi for!
Post #433651 25th Jun 2015 8:27pm
ATW
thanks for this!
delayed reply!
Post #812401 28th Jan 2020 11:08pm
Nearly five years has to be some kind of record Rolling with laughter Darren
Post #812429 29th Jan 2020 9:11am
Rkcorry
^^^ A bottle overboard..... Very Happy
Post #812441 29th Jan 2020 10:18am
ATW
haha!! my bad! Mr. Green Mr. Green
Post #812452 29th Jan 2020 11:31am
