Home > Puma (Tdci) > Cracked exhaust manifold |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5591 |
No help, but can I ask if you are running standard exhaust and cat?
I'm wanting to bin my cat, as I believe it's the cause of problems, as it slows the hot gases escaping due to its restriction. Andy |
17th Mar 2015 11:55am |
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 |
Are you sure its cracked?
Is your puma tuned or stock? I went a step further than you,now i have a cracked turbo http://www.defender2.net/forum/topic35766.html |
17th Mar 2015 12:14pm |
Egghead Member Since: 25 Nov 2012 Location: Surrey Posts: 255 |
Standard exhaust system, although I'm now going to put a stainless one in seeing as it's getting all the work done on it to replace the manifold. I had it remapped a couple of years ago - changed the driving completely! Pulls like a train and eats uphills like nothing I've known.
Not easy to take photos of the crack with everything in place but I will grab a photo soon if poss. Nasty looking with all the soot that has squeezed through it. Might have the manifold painted before it is put in with some high temp stuff. |
17th Mar 2015 3:37pm |
