![]() | Home > Td5 > HELP! |
TDfive Member Since: 02 Sep 2008 Location: somerset Posts: 51 ![]() ![]() ![]() |
have tried the fuel cap off trick no differance at all , when it has died pump is usually screaming like a strangled cat ------------------------------------------------------- 05 110 crew cab td5 1987 90 tc TD/200TDI DISCO CONVERTION ![]() |
It will do if it has no resistance and there's no fuel in it....Mind it doesn't overheat! Had a similar issue with my V8 Disco....that was down to corroded pipes and the sucking in of air as previously mentioned. Blow the system through and pressure test it! ![]() Treat every day as if it is your last....one day you will be right!! |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Try disconecting the multi-plug on the MAF sensor and see if it improves... common fault on the TD5 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Like it is said before if the pump is screaming it doesn't have fuel.
The pump is in the tank so the low pressure part off the pump will have fuel if there is fuel in the tank. As I understand the whole system is pressurized so it wouldn't suck air in. The fuel goes from the low pressure part off the pump to the fuel filter and from there to the high pressure part off the pump and I assume that the high pressure parts does the screaming. It looks to me that you have a problem between the low pressure part off the pump and the high pressure part. You mentioned that the filter was changed so you might have a blocked fuel line. If the fuel pressure is too low the ECU can switch off the engine. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
have replaced the fuel pump this week it did improve a lot but it still not releived the cut out problem ![]() 05 110 crew cab td5 1987 90 tc TD/200TDI DISCO CONVERTION ![]() |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
The reason the fuel pump is noisy is because it is pumping air.
This air is likely being sucked into the fuel system somewhere on the low pressure side of the pump - the pump sends fuel at low pressure from the tank through the filter, and then back to the pump where it goes through the high pressure pump and onto the engine. I might suggest that it is either the filter (unlikely as it was replaced) or the filter housing - I don't think it will be a fuel line as fuel would be leaking. I had a similar problem with my TD5 - noisy pump and lack of top end. It turned out to be a poor fuel filter. I did try testing the fuel system with compressed air which didn't diagnose the fault - air leaked into the system but not out! I used my clear fuel line (see below) for diagnosis. I suggest a new filter (as they're cheap) then a new filter housing (after rebuilding the fittings with new copper washers as they're cheap too). If it would be useful, I have a section of clear fuel line which I made up when trying to diagnose my air leak. It has the TD5 fuel line fittings - one male, one female - so you can fit it in between components and learn where the air is getting in. I'll gladly post it up to you as a loan if you think it will help? Or you can easily make one from a scrap fuel pressure regulator from the bin at your local LR place! My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
Simon,
I thought that the fuelpump is hanging in the fuel, so how can the low pressure pump suck in air? Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Roel,
It won't suck air in at the pump, but air can leak in on the low pressure side of the fuel system. Leaks on the high pressure side tend to physically spurt fuel out as it's 4.5 bar if I remember correctly. My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
thanks for that mate i might take you up on your offer of the loan of the pipe if i cant get any joy from it ![]() i have had a development today went into the local stealers for a new filter and asked if there was a differance between the fender and disco td5 filters, guy i bought it from gave me the currant filter as original was rusty and said they are the same .DOH!! ![]() they are different so could be my problem (keep yer fingers crossed for me ![]() 05 110 crew cab td5 1987 90 tc TD/200TDI DISCO CONVERTION ![]() |
Update on my problem i have been having .
After a lot of faffing about and much hair pulling (must say as time went on a gallon of petrol and a match looked a pretty good option ![]() Turns out it was the injector seals to fault ![]() all done and running sweet as a nut now many thanks for all your help ,hope that my misfortune in taking so long finding the problem will perhaps help solve others problem quicker cheers paul ------------------------------------------------------- 05 110 crew cab td5 1987 90 tc TD/200TDI DISCO CONVERTION ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 ![]() ![]() |
Thank you for spending the time to tell us what the problem was, it is so annoying when people don't inform us that have tried to help.
Glad it is all sorted Thanks Andy |
yeah i feel the same just hate it when the story dont gert finished ![]() must say been walking about like a dog with 2 dicks all day ![]() even treated her by ordering a new set of rubber (bfg mt's in 265/75R16 ![]() 05 110 crew cab td5 1987 90 tc TD/200TDI DISCO CONVERTION ![]() |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Very common problem! Easy to change though best to use genuine parts as a lot of aftermarket ones I've fitted the copper sealing washer is a vey poor fit on the injector nozzle and fails in no time at all. Genuine ones should be able to be gently tapped on using a bit of pipe or a deep socket that will fit over the injector nozzle. Cleanliness is key as when the injectors are removed the carbon from the tip tends to end up in the washer sealing area in the head....
i'm quite lucky in that a lad i go off-roading/green laning with has a good mate that works in the local stealership workshop ![]() left it to him to sort out was worth the delay of a couple of days till he got to it (and a fraction of what they would have charged me ) ![]() 05 110 crew cab td5 1987 90 tc TD/200TDI DISCO CONVERTION ![]() |
