Home > Puma (Tdci) > New car - pulling to left?
kbf1981
So picked up my new Defender 110 last week and I love it. Only issue I've found so far is that it feels like it's pulling to the left a bit, so steering has to be angled at maybe 12.30pm angle on motorways and most road. Reading around... I see a lot of threads on this, so:
1) do they all do it, and is it just the way it is? Or...
2) should I check tyre pressures, check wheel alignment (get dealer to do it as it's less than 1 week old), and whatever else I can think of that'd correct it?
Lovely car and I'm not massively bothered as it's only minor, and I respect that it is still hand made and you'll have bits and bobs on a hand made car.
Post #407740 15th Mar 2015 12:36pm
scotia
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Probably pulling to the left due to the camber of the road. To verify this, take it down a straight quiet country road and see if it pulls to the right when carefully driving on the right hand side of the road.
Post #407741 15th Mar 2015 12:47pm
JWL
I would check tyre pressures first and if no change get it back to the dealers and raise a fuss. It may be that the steering isn't centralised as if it was a mechanical problem you would be constantly steering away from the pull but the way you've worded it it sounds like the steering wheel isn't in the central position on a straight road.
Post #407756 15th Mar 2015 2:00pm
AndyS
Swop the two front tyres over. I once had a van that pulled to the left and it turned out to be a faulty tyre. They checked the alignment, balance and all sorts. Only really found it once the fronts had worn out and got replaced.
Post #407834 15th Mar 2015 6:14pm
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
First check tyre pressures and simple things first, then get the geometry checked out. If not it might be a tyre fault as Andy suggested. Dealer needs to sort that.
I had the problem when I got my 08 110 that was on the factory General Grabbers, had all the above checked, also changed tyres front to back, side to side and it still did it. Changed the tyres to new Coopers and it drives straight as a die now. Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #407909 15th Mar 2015 9:29pm
kbf1981
I'll check tyre pressure first. It may just be the camber of the road tbh.
Post #407987 16th Mar 2015 10:20am
Merlin
Mine was like that. The stealership never sorted it. So I just kept swopping wheels until the problem went, then I marked the inside of the 'hub cap' to show which went where. Strange thing is, it isn't like that with the winter tyres, drives straight as an arrow.
Merlin
Post #408106 16th Mar 2015 3:53pm
Naks
mine also jumped to the left since new (2010) - couldn't take my hands off the steering wheel at any speed over 40kmh.
after 2 years of LR telling me 'they all do this', I got my lawyer to write them a nice letter.
they bent over backwards and started replacing parts - rims, shocks, coils, etc. Eventually they replaced the front axle, and the problem was resolved.
Now I can drive 100kmh and take my hands off the wheel without ending up in the bush Thumbs Up --
Post #408192 16th Mar 2015 6:14pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
This used to be a common fault when I was doing the PDI at the main stealers .
The ring of bolts that holds the swivel housing to the axle casing has a dowel bolt in the top hole. We used to remove the bolt and grind the dowel part of the shank off. refit the bolt and jack up the front of the swivel housing before tightening the ring of bolts.
This then gives you an increased castor angle and prevents the pulling to one side, it only takes about 15mins Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #408406 17th Mar 2015 2:54pm
Juhulia
2012 Defender 110 Puma 2.2 SW Keswick Green
Well, this is a new car.
I suggest you consultate your local Land Rover Dealer with this issue.
Post #408499 17th Mar 2015 7:32pm
kbf1981
Will give dealer a shout. Can you take a new car into any dealer or is it best to take it to the supplying one? Tbh supplying one is a 45 min drive and there are closer ones to home.
Post #408630 18th Mar 2015 10:54am
GUM97
Just take it to the nearest one! (Well, in Manchester not Williams and ideally not Stockport!!) Thumbs Up An engine to TDi for!
Post #408790 18th Mar 2015 7:05pm
kbf1981
Do Williams and Stockport not have a good reputation? They're the two nearest me, then Bury! Bury seemed ok when I looked around!
I've inflated all the tyres to 30psi on the fronts and 48psi on the back (as recommended), and seems to have sorted it tbh so alls good. Probably just rear tyres as they were a little low, fronts were perfect!
Post #408877 18th Mar 2015 11:20pm
GUM97
Have you thought about Knutsford? Thumbs Up An engine to TDi for!
Post #409041 19th Mar 2015 6:03pm
