![]() | Home > Maintenance & Modifications > defender td5 raised breathers, seperate pipes or joined? |
I wouldn't expect any problems with this as if oil is really coming that high in the breather soemthing is wrong anyway and you have to change the oil anyway.
I don't expect problems from oil fumes going from the gearbox into the transfer box or the other way. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8155 ![]() ![]() ![]() |
i agree in that i dont think fumes would be an issue. that said my auto when she gets hot on a long winch (300ft ish) climb over a certain gradient will chuck some ATF out the breather, if i had combined breathers this could be a problem.
I wouldnt worry about it. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
