Home > Maintenance & Modifications > defender td5 raised breathers, seperate pipes or joined?
hugh_b
Hi chaps, I fitted raised breathers to my td5 90 yesterday however i'm a little concerned due to a few things i have read since.
I have basically run the rear diff breather to the front and up infront of the bulk head to meet with the other 3 breathers for transfer box, gearbox and front diff. From here I have put both diff pipes into a y connection and one pipe from this up to the snorkel. I have done the same with the transfer and gearbox.
I've been told that due to the transfer box and gearbox having different oils I should have seperate pipes for these so 3 in total up the snorkel as opposed to the current 2. Can anyone confirm this?
Apparently it's due to possible contamination of the oils once the engine has cooled and remaining gasses condensed.
Hugh
Post #40759 17th Sep 2010 6:20pm
roel
I wouldn't expect any problems with this as if oil is really coming that high in the breather soemthing is wrong anyway and you have to change the oil anyway.
I don't expect problems from oil fumes going from the gearbox into the transfer box or the other way. Roel
2003 90 Td5 (2009-now)
Post #40767 17th Sep 2010 7:09pm
jst
i agree in that i dont think fumes would be an issue. that said my auto when she gets hot on a long winch (300ft ish) climb over a certain gradient will chuck some ATF out the breather, if i had combined breathers this could be a problem.
I wouldnt worry about it. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #40777 17th Sep 2010 8:34pm
