Home > Puma (Tdci) > Performance intercooler
Def Junkie
Hi,
I am looking to buy a new performance intercooler as the one I have has been split in 2 places - no idea how.
I have got a re-map from BAS. Any suggestions as to what intercooler to go for - I am looking at BAS and Alive.
Many tks.
Tim
Post #406172 10th Mar 2015 5:46am
dgardel
Italy
Pete at BAS may suggest you the best solution (Allisport?) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #406181 10th Mar 2015 8:09am
Pickles
If you've got a BAS tune, then surely BAS would be your first call?
Pickles.
Post #406189 10th Mar 2015 8:37am
Have you ruled out a repair on your existing one. Unclear from your post above as to whether this is standard or upgraded already?
Post #406203 10th Mar 2015 9:23am
Def Junkie
Pickles.
They were my first call but I keep getting referred to by Pete to their website (www.bellautoservices.co.uk) which for some reason is not opening up on my browser. Hence why I have been looking for alternatives.
I haven't ruled out a repair on the existing which is an upgrade that I got from LR Parts. But figured that if that has cracked in less than 10 months of use, it can't be very good and didn't want to throw more money on something that has already proven to be unreliable Sad
Post #406230 10th Mar 2015 11:13am
dgardel
Italy
https://secure.bellautoservices.co.uk/stor...tercooler/
IID Pro MV License
Post #406296 10th Mar 2015 2:25pm
Understand where you are coming from - out of interest have you been in touch with LR Parts?
Post #406400 10th Mar 2015 8:08pm
Def Junkie
No I haven't been in touch with LRP. While my first order with them which included the intercooler went really smooth the 2nd order which was a much smaller one was quite the opposite. It never arrived and ultimately the order was refunded after they found out that the order never left the uk. I had to do a lot of chasing and following up before it got finally sorted. Didn't have much hope thereafter of any redress with the intercooler Sad
Post #406608 11th Mar 2015 3:13pm
Fatboy Slim
Wales
I recommend alives offerings in the intercooler department. I wouldn't have an allisport one given to me after the last one I had rotted out in under 10k miles. Cheap rubbish core.
Post #406652 11th Mar 2015 6:31pm
roel
You will get an bigger/performance inter-cooler to get the inlet temperature down. I know lower is better but what is a max temperature to aim for? Roel
2003 90 Td5 (2009-now)
Post #406672 11th Mar 2015 7:19pm
K9F
Roel,
I don't think you can quantify a target figure as there are too many variables, ambient temperature altitude/millibar reading etc. Suffice to say lower is indeed better and you know that already.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #406679 11th Mar 2015 7:35pm
