![]() | Home > Puma (Tdci) > Performance intercooler |
Pete at BAS may suggest you the best solution (Allisport?) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3792 ![]() ![]() ![]() |
If you've got a BAS tune, then surely BAS would be your first call?
Pickles. |
Have you ruled out a repair on your existing one. Unclear from your post above as to whether this is standard or upgraded already?
Def Junkie Member Since: 30 Dec 2013 Location: Somewhere in Paradise Posts: 79 ![]() |
They were my first call but I keep getting referred to by Pete to their website (www.bellautoservices.co.uk) which for some reason is not opening up on my browser. Hence why I have been looking for alternatives. I haven't ruled out a repair on the existing which is an upgrade that I got from LR Parts. But figured that if that has cracked in less than 10 months of use, it can't be very good and didn't want to throw more money on something that has already proven to be unreliable ![]() |
https://secure.bellautoservices.co.uk/stor...tercooler/
![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Understand where you are coming from - out of interest have you been in touch with LR Parts? |
No I haven't been in touch with LRP. While my first order with them which included the intercooler went really smooth the 2nd order which was a much smaller one was quite the opposite. It never arrived and ultimately the order was refunded after they found out that the order never left the uk. I had to do a lot of chasing and following up before it got finally sorted. Didn't have much hope thereafter of any redress with the intercooler
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
I recommend alives offerings in the intercooler department. I wouldn't have an allisport one given to me after the last one I had rotted out in under 10k miles. Cheap rubbish core.
You will get an bigger/performance inter-cooler to get the inlet temperature down. I know lower is better but what is a max temperature to aim for? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Roel,
I don't think you can quantify a target figure as there are too many variables, ambient temperature altitude/millibar reading etc. Suffice to say lower is indeed better and you know that already. ![]() Treat every day as if it is your last....one day you will be right!! |
