Home > Puma (Tdci) > Missing Roll Bars
Page 1 of 3 123>
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Missing Roll Bars
Ok so I have been driving around enjoying my defender when naturally thoughts come to upgrading suspension etc... SO I have been reading about upgrading anti roll bars etc thinking this is a nice simple job for a man that's handy on the spanners.
So I look underneath and I cannot for the life of me see any anti roll bars! front or rear.
Now my 2008MY Puma started life as an MOD RAF county spec 90 not sure if that means they were not fitted with any but I cant find them!
Assuming they are not actually there does anyone have any pics or diagrams of what they should look like and what connections are needs as I think for motorway and road use they would be a useful addition.
I have uploaded some pics in case that helps
Post #406562 11th Mar 2015 12:46pm
Snowy90
Also a few pics from the rear suspension
Post #406565 11th Mar 2015 12:53pm
Jimbob
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
For some reason you don't have them your correct, they should look like this:
Although not orange as these are aftermarket uprated ones but Orange makes them clearer for you to see in this instance 😊👍
They bolt to those large flat plates you can see in your picture on the chassis rails 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader
2015 Defender XS Hard Top (awaiting delivery 😄)
Post #406568 11th Mar 2015 12:58pm
Snowy90
Hmmm yep mine are missing alright thanks for the picture that's very clear.
certainly on the front I just have empty brackets.Did your upgrade kit come with bushes clips and drop link?
Post #406570 11th Mar 2015 1:15pm
Jimbob
You do on the rear too you can see them they are at a different angle to the front ones up by the fuel tank (can just see them at the top of your last but one photo) and come down to the two empty tabs on the back of the axle, sorry that's just an image off google not my defender unfortunately but I believe the website was called xtreme 4x4 that sold that kit if you want to look and see what it comes with Thumbs Up 2009 Defender County Hard Top (gone 😞)
Post #406573 11th Mar 2015 1:21pm
County spec didn't specifically include ARBs - my County-spec 2007 double cab doesn't have them.
I am not sure if it is/was the model type or the spec level which determined whether or not they were fitted. I think that the vehicles which are essentially more "commercial" don't have them (pickups, hardtops, double cabs) whilst those which are more passenger-vehicle-like do have them (station wagons).
I am sure that someone with the answer will be along. Retrofitting ARBs is easy under normal circumstances.
Post #406574 11th Mar 2015 1:27pm
Snowy90
Sorry are you saying you can see the rears? Just looked at the extreme website
mine has the empty brackets on the axle but its not clear where they attach below/beside the fuel tank.
Either way looks like I need to get some!
Post #406575 11th Mar 2015 1:32pm
Snowy90
Thanks Blackwolf, I suspect being a RAF county it was paired right back to what was essential it looks like it has the bracket but none of the hoops or drop links
So at least it looks like they haven't been removed.
Will need to track down the parts it would be good to fit an upgraded bar rather than standard
Post #406577 11th Mar 2015 1:39pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I don't think you got arb's unless it's an XS that came standard with alloys or specced alloy wheels, strange that the alloy wheel option also came with ARB's
Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #406671 11th Mar 2015 7:17pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Ah..that makes sense now. Browsing the brochure recently I had noticed that the Style Pack includes ARB as well as alloys. This was the only place i noticed any mention of ARB and wondered why it came with a "style" package rather than "performance" or "safety" etc.
Interestingly the Style pack is not an option on the SW - so this means the current SW base model already has ARB (even with steel wheels) or the ARB is included when upgrading to alloys but the brochure doesn't mention it?
Post #406689 11th Mar 2015 7:48pm
barbel jim
Just fitting standard roll bars will be a BIG improvement !!! I bought mine from a fellow forum member for a few , Once fitted didn't see the need for anything more. Standard rears are easily available, and they are advertised on here regulary. Put up a Wanted thread, I'm sure someone will oblige you
Post #406691 11th Mar 2015 7:57pm
Fifth Horseman
That may be correct re the "commercial" variants, my old '07 XS double cab didn't have them either.
Post #406705 11th Mar 2015 8:34pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
The picture of the rear orange arb shows it fitted wrongly.
The knuckles on the rear axle are the wrong way up, they are hanging below the axle and need rotating......just in case you are intrested......never mind......I will get my coat Embarassed 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #406713 11th Mar 2015 8:44pm
YOLO110
Australia
... but if you are doing a lot of off-roading, having the ARB's off does give you better axle articulation. YOLO... You Only Live Once...
Post #406739 11th Mar 2015 9:42pm
Something must have changed later then as my MY13 XS double cab (with HD steel wheels) does have then front & rear, and I didn't especially spec them.
Included on Build Configuration Sheet as:
Anti Roll Bars : Front & Rear Anti-Roll Bar [027BD]
Post #406879 12th Mar 2015 11:47am
Page 1 of 3 123>
