Home > Maintenance & Modifications > Puma clock Light Bulb
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Hi all !
I need the Part Number for Puma clock Light Bulb .
Thanks ! Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #406547 11th Mar 2015 12:30pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Theater
Have a read here:
http://www.defender2.net/forum/topic35056.html?highlight=clock
Thumbs Up 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #406549 11th Mar 2015 12:38pm
Theater
Thanks !
Thumbs Up Marco
Post #406550 11th Mar 2015 12:40pm
Martin
Site Admin
The clock bulb is not in the parts catalogue.. well, it is, but as a "Not Separate Part" item Shocked
Do you have a photo of the old bulb?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #406551 11th Mar 2015 12:41pm
Theater
I haven't photo of the old bulb. .
I want buy the new bulb before to remove the clock from the center dash .
I have a Puma 90 My 2010.... Marco
Post #406685 11th Mar 2015 8:40pm
Theater
Can I use this bulb ?
12V 2W BX8.4d
http://www.tme.eu/it/details/bx8.4d-2w-osr...2352mfx6/# Marco
Post #406874 12th Mar 2015 12:33pm
jomara
This is the bulb with holder mentioned in the previous thread, the bulb seems longer and the contact locations are different
http://www.rimmerbros.co.uk/Item--i-STC1205 2014 110 2.2TDCi XS Station wagon
Post #406876 12th Mar 2015 12:40pm
Martin
Site Admin
STC1205 is the hazard switch bulb  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #406877 12th Mar 2015 12:41pm
jomara
Bummer!! Sorry Crying or Very sad Embarassed 2014 110 2.2TDCi XS Station wagon
Post #406889 12th Mar 2015 1:18pm
jomara
Shows the bulb but no part number Confused
Post #406892 12th Mar 2015 1:26pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Its literally a couple of minutes to remove the centre dash - two bolts on either side then just ease out 6 (or 8 ) clips
Post #407041 12th Mar 2015 9:26pm
Devon-Rover
Being Land Rover it'll either be completely unique or utterly simple. does any one have a picture of said bulb + holder? There is a few different versions of those little capless bulbs and holders but perhaps the parts bin mentality of land rover mean it is something obvious like a Disco 2 clock bulb!
Post #407049 12th Mar 2015 9:50pm
Rickydodah
This is the part I bought for mine.
http://www.ebay.co.uk/itm/CAR-BULB-12V-509...rmvSB=true
The original bulb has a green plastic sleeve over the glass part of the bulb to give green hue to the illumination. As the new part was a clear lense I used a green felt tip pen to colour the glass before fitting. Thumbs Up I started with nothing and still have most of it left!
Post #407052 12th Mar 2015 10:03pm
ericvv
So the jury remains out on this.
I do remember that when my own hazard switch bulb failed, my dealer in their system could also not find the STC1205 bulb listed as a separate item for the Puma anymore. So PaulMc on here came with the educated explanation as below.
PaulMc wrote:
This Hazard Warning Lights Switch has been used in the Defender since the 2002 dash update (not to mention the variant used previously in Discovery 1, Soft Dash RRC and Rover cars), it has always had night-time illumination.
As for the switch's bulb, it's not listed in Microcat for the 2002-2006, or 2007 -> Defenders (so most dealers tell you it's not replaceable and try to get you to buy a complete new switch).
It is replaceable, it's listed for the 300Tdi Discovery 1 Hazard Warning Lights Switch (which is essentially the same switch, but vertical instead of horizontal), its part number is -
STC1205 - BULB & HOLDER ASSEMBLY, CLEAR
I wonder if with the original Puma green clock bulb we have a similar situation as above. Could it be that the bulb was listed for clocks in older LR models, or for other than Defender models, just not for the Puma (and maybe not for the Td5) anymore? Quite likely that the Puma clock was borrowed from a different LR/RR model, just like the entire speedo unit which is borrowed from the D3.
Anyone (PaulMc??) can enlighten us? One day or the other we all will face this situation that our Puma clocks will go black.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #407120 13th Mar 2015 5:05am
PaulMc
I haven't studied the Puma's clock too closely - so, I don't know what it uses for its illumination, or if it's easily replaceable.
However, the picture in Microcat references the bulb as 'NSP'
Replacing the complete clock (at around £54.00) seems a bit extreme, just because the bulb has blown Shocked
Anyway, I have the connectors to fit this clock, and they are marked as 'Ford Restricted' items - so, I wonder if this clock has its origins in the Ford parts bin Question
. Paul.
Post #407215 13th Mar 2015 12:38pm
