Home > Maintenance & Modifications > ARB Compressor Mounting
LandyBen82
United Kingdom 2012 Defender 90 Puma 2.2 HT Firenze Red
Where and how have you mounted on board compressors? I have been told under the passenger seat is a good place (I only run one battery).
I will be using it to activate air lockers and for handy tyre inflation.
Thanks in advance - Ben
Post #406209 10th Mar 2015 9:56am
walfy
Where ever you mount it ensure it is on rubber mounts. It will vibrate and cause lots of vibrations when it's running. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #406213 10th Mar 2015 10:13am
LandyBen82
I have got loads of thick rubber washers at work, they might work??
Post #406215 10th Mar 2015 10:19am
walfy
Trial and error I think. Try and position it near some bracing. ie if you mount in on a flat panel then try and do it where the bracing runs on the otherside. Or mount in a corner where the panels have less scope for vibrating.
Ensure you use the backing plate that comes with the compressor. That will help a lot as well 110 D250 SE HT
110 USW SOLD
Post #406238 10th Mar 2015 11:26am
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
Not sure which model 90 you have or what size compressor you have but in my 90 HT with no rear bulkhead I have mine mounted on behind the driver's seat, on the top of the rubber matted wheel box.
I have quite a lot of non-standard gubbins in there - fuse box, roll cage and load barrier (dog guard) but it fits fine. Done 15k miles around Australia on a lot of rough tracks and not had any problems with it, and no vibrations to speak of.
Usually the air line is coiled a bit tidier than in the picture and tucks away down the side of the roll cage. Been a bit lazy with my tidying up of late! Still loads of "Red Centre" sand in there!
 Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #406245 10th Mar 2015 11:57am
Mo Murphy
Mine is behind the passenger seat next to the rear bulkhead.
50 Shades of Pennine Grey
Post #406302 10th Mar 2015 3:03pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Mine is mounted between the passenger seat and the bulkhead, mounted on the bulkhead. Been there 5 years, no vibration and accessible for tyre inflation. 2007 TD5 90 Hard Top
Post #406463 10th Mar 2015 11:01pm
LandyBen82
So is it a big job to get under the passenger seat. I will wait for it to arrive and have a good scratch of the head.
Thanks - Ben
Post #406505 11th Mar 2015 8:49am
MK
Mine is located under the front left wing (LHD). It has been there for years and no trouble at all. Puma 110" SW
Post #406514 11th Mar 2015 9:19am
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Mines behind the driver headlight with the airline running to the gmb wingtop storage locker 2004 TD5 Defender 90 xs station wagon
Post #406532 11th Mar 2015 10:19am
keith
Post #406571 11th Mar 2015 1:17pm
