Home > Technical > Bracket on 110 front diff
Autolycus
This bracket was attached (two BSF set screws) under the nose of the front diff casing on my 1991 200tdi 110 csw.
What's its function? The track rod had been rubbing quite hard on one of the "jaws", and more lightly on the bottom of the jaw. There's no hydraulic steering damper - is this intended as a friction damper?
Thanks.
Kevin
Post #405459 7th Mar 2015 9:53pm
It's to offer 'support' if it gets knocked, to stop the rod bending. If yours has been rubbing, something ain't right, or someone has put thicker rods on and not binned the 'bracket'.
Post #405462 7th Mar 2015 9:56pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Just to try and prevent any 'bendage' if the off-road stuff gets too rough. As said, if the track rod is rubbing then it must be bent. I have just binned mine after fitting a Simmonites Dam bar over the original tube.
Post #405466 7th Mar 2015 10:09pm
Autolycus
Thank you both, very much.
I'll check the tube for straightness, and I'll either apply BFI or add one to my next order. Can even BP get these wrong?
Kevin
Post #405514 8th Mar 2015 8:52am
I think you'll find the setscrews are UNF not BSF (60º thread form not 55º).
Post #405834 8th Mar 2015 11:09pm
smb
It could be the angle of the photo, but that bracket looks as if it has been bent downwards which would probably account for the wear on the upper inside face.
Post #405842 9th Mar 2015 12:03am
I Like Old Skool
That is how they are made, and it is a chunky piece of extruded aluminium, I expect the bolt heads would snap before the bracket bent at that point.
Post #405903 9th Mar 2015 9:45am
Autolycus
Thanks for the further comments.
The bracket is "bent" on its top face, but, as ILOS says, it looks as though it was made like that.
I'd have expected UNC or ISO metric threads, but they're definitely 3/8 BSF, 20tpi. I wonder if the diff housing has had to be re-tapped from 5/16 or M8? One of the mucky-trucky's many mysteries.
Kevin
Post #406398 10th Mar 2015 7:59pm
I've just looked them up on Microcat and you are absolutely right, they're 3/8" diameter x 20tpi, 5/8" long, BSF setscrews. I had naively thought they'd be UNF since the propshaft bolts and the studs that secure the pinion housing in the axle case are 3/8 UNF.
I wonder if the Defender is the last production vehicle in the world to use Whitworth, Unified and ISO thread forms all on the same component!
Post #406457 10th Mar 2015 10:44pm
