Home > Technical > Headlight/instrument light Relay
LittleFoot
Hi all, another 110 issue appeared last night (always seem to be appear after trip to dealership Big Cry )
Went to move vehicle last night but when I pushed the light switch on for instrument lights/headlights there's a loud buzzing/rattling sound....assume a relay? All lights seem to function ok but with this awful noise.
With lights switched off there's no noise when flashing headlights.....The vehicle is 2012 Puma and I changed out the original factory fit SVX Crystal Wipacs for Nolden Bi-LEDs a month or so ago....any ideas or any one seen the same issue?
Cheers all,
Post #404902 6th Mar 2015 8:09am
K9F
The headlight switch itself can be prone to failure. A buzzing relay is indicative of the stalk switch issue, it may not manifest itself whilst flashing but in the normal position only. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #404904 6th Mar 2015 8:13am
LittleFoot
Thanks K9
After looking this morning it now seems that the issue is a rapid clicking/popping noise coming from area behind right hand led headlight when swith is put on....can't tell it's the light itself.
Post #404924 6th Mar 2015 9:08am
LittleFoot
Job done, replacement light en route. Bit of a pain but hopefully a one off.
Thumbs Up
Post #405024 6th Mar 2015 3:25pm
jzk841
United Kingdom 2008 Defender 90 Puma 2.4 CSW Tonga Green
clicking behind headlight
Hi, did you find the cause of the clicking behind the headlight ? mine has just started and only happens when I switch the lights on... not sure why ! have new lights that I have just put in. any help appreciated its driving me nuts !
Post #498269 30th Jan 2016 4:35pm
LittleFoot
Hi - I fitted a replacement LED light and the problem didn't return. Light was apparently tested ok so it may possibly have been a wiring irregularity due to fitting.
I'd suggest popping the grill off and checking all your connections carefully. Maybe swap the lights round and see if you still get the same issue?
Post #498290 30th Jan 2016 5:21pm
