Home > Puma (Tdci) > economy |
caribcat Member Since: 11 Jun 2009 Location: Anglesey Posts: 97 |
110 CSW XS 320 - 360 on a tank, but 50% of that time is towing boats up and down a mile long hill in 2nd and 3rd. Got over 400 on a tank once motorways at 65mph.
DeCat pipe coming soon which apparently should make a big difference, but so would smaller boats...... Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
13th Sep 2010 5:53pm |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Well I've just ticked over the 400 mile mark, I know thats not a lot but it had 1/4 of a tank in when I picked it up and I have since filled the tank twice and have got just under the 3/4 of a tank still in the tank with just over a 110 miles in the trip.
I don't think I'm getting anywhere near your figures |
13th Sep 2010 6:47pm |
fekete, did your performance/economy improve or just the soundtrack?!
13th Sep 2010 7:17pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Hi not that i could tell on the fuel but i'm one of them when it needs fuel i fill it.... never really check what its doing to the gal
The truck does pull more with the pipe on i took K9 out in it and he reckons it sounds like kit out of night rider...you can really hear the difference NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
13th Sep 2010 7:27pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
bought it 2nd hand, now done 5k, i've only done 1600 miles so far.
checked 1 tank and it did 28 on a 250 mile round trip. i have promised myself i won't check again BM52 |
13th Sep 2010 8:59pm |
My main reason fo checking the MPG is I do a lot of Aberdeen to Norfolk drives and need to plan my off motorway reasonable priced fuel stops. I normally fill up in Aberdeen and then in Penrith and that'll see me home.
13th Sep 2010 9:15pm |
100 / 9.58 = 10,438 L/100km Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
13th Sep 2010 10:05pm |
p-j Member Since: 08 Aug 2010 Location: belgium Posts: 4 |
My puma 90 also uses like 10L/100km
(with roofrack) I drive mostly to work doing 80 to 90 km/h in sixth gear so I don't expect any lower numbers |
23rd Sep 2010 10:21am |
p-j,
Welcome to the forum, by my calculations that is a very reasonable economy for a 90. In imperial it equates to about 28-30mpg. Not bad at all! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
23rd Sep 2010 11:04am |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 546 |
The best I got was 8.50 l/100km on my 90, but it varies a lot and it seems to be going up nowadays... No roofrack, no snorkel, no aircon. |
23rd Sep 2010 11:11am |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
I tend to run up and down the motorways alot from Cornwall to London at 55-60mph (2000rpm) in the 110 and get a good 400 miles from a tank, (with brownchurch roofrack and lots of junk in the back..)
but went to Goodwood at the weekend and ran back at 70 all the way - only got 350 out of the tank ... so wont be doing that too often! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
23rd Sep 2010 11:42am |
heinrichnel Member Since: 07 Apr 2010 Location: Windhoek, Namibia Posts: 42 |
While on vacation in South Africa I did a trip from Port Elizabeth to Pretoria and a bit of driving around there. Traveled about 2400km, 99% highway driving, doing 90% of the time 130-135km/h GPS speed. Used 365 lt for the entire trip. Average of 6.57km/l. I am running a 2" TJM lift, BFG Muds, ARB bulbar, Roof light bar with 4 IPF light, National Luna 90l fridge, dual batteriers, 45lt extra tank and outback draw system in the back in a 110 Puma with Dastec performance chip. So a little higher and heavier than normal. I am sure I can get better consumption, but why?
23rd Sep 2010 1:03pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20510 |
So the D cat pipes fully legal and is a simple swap out? |
23rd Sep 2010 4:22pm |
Konabikes,
You have to unbolt a crossmember I believe or cut your old pipe to get it out! I'll do a search it's on here somewhere??? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
23rd Sep 2010 4:30pm |
