Home > Group Buys > Nakatanenga Third Group Buy Stainless Bolt Kits
Sign Up
(16)
(18)
User Registered Confirmed
defender_uk25th Jan 2015 2:48pm
stu_00725th Jan 2015 3:55pm
JAY BOY25th Jan 2015 4:04pm
Bev25th Jan 2015 6:05pm
Fozzauk25th Jan 2015 6:34pm
stevie d25th Jan 2015 6:52pm
Vince VDB25th Jan 2015 11:48pm
nitram1726th Jan 2015 2:16am
s1charger26th Jan 2015 6:20am
X4SKP26th Jan 2015 10:16am
BIGJOCK9026th Jan 2015 8:23pm
prezzy27th Jan 2015 8:34pm
nicholas201228th Jan 2015 10:47am
Tank4th Feb 2015 11:34pm
chinnus21st Feb 2015 7:17pm
hxk49426th Feb 2015 10:12am
Crawford25th Jan 2015 4:15pm
keith25th Jan 2015 4:26pm
GEllis25th Jan 2015 5:34pm
landy andy25th Jan 2015 5:53pm
bear10025th Jan 2015 6:13pm
TJ10125th Jan 2015 7:32pm
mega25th Jan 2015 7:45pm
Iain25th Jan 2015 8:43pm
Inigo25th Jan 2015 9:08pm
smb25th Jan 2015 11:00pm
scotia26th Jan 2015 7:58pm
mk1collector27th Jan 2015 3:16pm
YeomanOfTheBar28th Jan 2015 3:36pm
jomara5th Feb 2015 10:55am
Zakros1st Mar 2015 1:06pm
D922MAT16th Mar 2015 11:06am
SteveD13th Jun 2015 7:07am
nicks30th Jun 2015 4:32pm
Page 7 of 7 <1234567
leeds
Nakatanenga basically does two main bolt kits Vast 90 and Vast 110. However there are options within the two rather broad classifications such as aircon and non aircon, SVX finish etc so there may be more bolts then what you actually require.
We then have to deal with the minor issue that Land Rover over the years can use different size bolts in the same position.
For instance the bonnet rubber bump stops in Catherines photograph shows 4 bump stops however only two are needed. However LR has used two different thread sizes, so two pairs of bump stops are provided, so you will have two left over.
Do not worry if you have some bolts left over.
Brendan
Post #397799 10th Feb 2015 10:43pm
Bev
Scotland 2003 Defender 90 Td5 CSW Oslo Blue
Excellent..... So im not going mad then. Just got the rear bolts on the chassis to go and then we are done.... Need to order a new t40 torx bit though as apparently mine is made of swiss cheese and wont undo the rearbolts.
The stainlees steel looks ace against the tonga green paintwork though and really sets of the appearance... 2002 Td5 | 90 County Station Wagon | Oslo Blue
2006 Td5 | 90 County Station Wagon | Tonga Green (Gone )
2002 Td5 | 90 County Station Wagon | Zambezi Silver (Gone)
Post #397822 11th Feb 2015 9:01am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
The T40 impact driver bits are a lot stronger, I stripped two standard ones when I fitted the wheel carrier to the Td5!!
Similar to the one i picked up Thumbs Up
https://www.google.co.uk/shopping/product/...CG0QpiswAA 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #397831 11th Feb 2015 9:33am
Spray them with WD40 the night before, helps a lot.
I do as a matter of course every time unless it's small ones and even then it doesn't always work they won't always come undone too easy.
If you can get to the rear cheating the threads also helps a lot.
But soak the whole bolt and nut in wd40 in advance.
Post #397842 11th Feb 2015 10:19am
leeds
This group is rapidly heading to its closure date.
IF you have NOT registered your interest with barbara@4x4overlander.com by MIDNIGHT tonight 28th February 2015 it will be a case of you are too late.
So it is over to you folks
Brendan
Post #403114 28th Feb 2015 6:51pm
leeds
Hmmm, it looks like some people are colluding with Barbara to circumvent the grumpy old gits deadline.
Or should that read Barbara is colluding with certain people to get past my deadlines?? Whistle
Brendan
Post #403439 1st Mar 2015 6:15pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Have I missed this again?
Post #403577 2nd Mar 2015 8:37am
leeds
Blimey can not people read?
Barbara is colluding with people to circumvent my deadlines.
I do not understand why people are still emailing barbara@4x4overlander.com about things. All I know is I am given packing notes and told to get on with it.
I do not know when Barbara is colluding with people to circumvent the grumpy old git Razz
Brendan
Post #404819 5th Mar 2015 8:30pm
