Home > Puma (Tdci) > What is going on |
Mike,
Mine was similar...look here: It may help steer you to a solution: http://www.defender2.net/forum/topic2394.html?highlight=abs Especially this post from that thread: If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th Sep 2010 9:39am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
Thanks
But i checked the route of the cable when i saw the post and it all seems ok - unless the chaffing is in a place i cant immediately see... Mike |
11th Sep 2010 5:41pm |
Mike,
If you're technically able, got the wiring diagrams and an insulation/continuity tester and the time a half hour check would determine the servicability of the wiring! If not you'll either need to take it in or find a decent sparky! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th Sep 2010 6:39pm |
I technically competent - just usually cant be bothered
Is there a point where it went. I wonder given 3 times in 3years, if its a wiring fault, but i suppose it has been a concentration within the last 1.5years Mike |
11th Sep 2010 8:34pm |
Mike,
As you know intermittent snags are the worse to find! Even the dealers struggled to find mine until it had become permanent! Three times in three years is not much if it is working...with Winter and the crap weather associated with it your snag may manifest itself a little more??? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th Sep 2010 9:32pm |
I know the system is working, what off roading ive done in the last few months has had it on...lastly on a odd, but good, hill climb - short grass affair now diff lock engaged (i wanted to see if it would and it did )
It could be worth another look underneath (which is why i wondered if there were any "pinch points") I did wonder if it was something like dirt or similar throwing a fault that then clears itself by its own self check...we had a VW that did that with its ESP. Like you say i dont want it to fall over and cost more ££ Mike |
11th Sep 2010 9:41pm |
