Home > Group Buys > Folding Key into Alarm fob
Sign Up
(7)
(9)
User Registered Confirmed
Romadog9th Jan 2015 5:41pm
Lambley9th Jan 2015 6:02pm
rallysteve9th Jan 2015 9:26pm
deplec10th Jan 2015 12:11pm
LR Sam10th Jan 2015 4:30pm
chris d312th Jan 2015 1:37pm
Lrd3ruud14th Jan 2015 2:51pm
Lorryman1009th Jan 2015 7:52pm
carrotbay10th Jan 2015 10:41am
smb12th Jan 2015 6:09pm
Brewstop13th Jan 2015 7:35pm
Mazzaman3214th Jan 2015 4:55pm
Nobby14th Jan 2015 10:48pm
Allan c.15th Jan 2015 5:59pm
log1115th Jan 2015 10:22pm
Shirty Carpet20th Jan 2015 10:18pm
Page 4 of 6 <123456>
SGH
I have Xeng shroud on mine so need to get my key cancelled then as just sent it to Brendan. Sad 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #403227 1st Mar 2015 7:17am
SGH
ZeDefender wrote:
I know this is a one-off and I don't know if it's been discussed elsewhere but if you have an X-Eng ignition barrel sleeve, the key isn't long enough to go in all the way and turn (at least on mine). Please correct me if it works on others. In any case I didn't ask for refund because it's my problem Wink
All I did was put the circuit board back into the original fob and chalk it up to experience Thumbs Up
Matt
Matt did you get your key from Nakatanenga ? 993 Varioram - Guards Red
Post #403262 1st Mar 2015 9:13am
ZeDefender
Yes, a few weeks ago.
Service was great - it's just bad luck Sad Tell someone you love them today because life is short.
Post #403286 1st Mar 2015 10:33am
SGH
Post #403291 1st Mar 2015 10:47am
Lorryman100
@ZeDefender. Matt when you fitted the barrel shroud did you ensure the face of the ignition was tight against the shroud?? The reason I am asking is that I have one of these key fobs and it definitely works on my Puma with a X Eng ignition barrel shield fitted?
Key inserted in Off position
Ignition in position 2
Puma started and idling
Close up of key fob and ignition
HTH :thumbsup:
Post #403346 1st Mar 2015 1:52pm
ZeDefender
Yes, it's tight up against it. I suspect it might be a bit hit-and-miss depending on your key... Tell someone you love them today because life is short.
Post #403388 1st Mar 2015 3:33pm
ZeDefender
I just double-checked and there is less than 1/2 mm gap:
Is this a different ignition barrel design to yours?
My original key is quite a bit longer and I don't know the tolerances but even if some keys just catch and turn I still wouldn't take the risk of getting stranded, as some Puma locks are a bit "iffy".
I couldn't see any way of modifying it and since Nak had kept up their end of the bargain, I just binned it. Luckily the original key and the empty fob are sent back with the flip so it only took a few seconds to put everything back to normal.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #403397 1st Mar 2015 3:47pm
Lorryman100
When I originally fitted the shroud I noticed there was a couple of mil clearance from the LR key and the shroud
And when I measured the LR key the shank length is 45mm, the new fob shank is exactly the same length hence why I have had no issues with the Nakatanenga key fob and the X Eng barrel shroud.
HTH :thumbsup:
Post #403429 1st Mar 2015 5:39pm
ZeDefender
Rolling Eyes bloody LR Laughing
Although, admittedly, I no longer have the Nakatanenga key to measure it. I discounted the possibility of it being cut badly as it unlocked the door. It was definitely shorter though as I checked at the time. Tell someone you love them today because life is short.
Post #403459 1st Mar 2015 6:43pm
ljjnr
Any chance of another batch going ahead?
Post #434151 27th Jun 2015 11:07pm
K9F
Whilst this may be a convenient and handy modification does anybody actually consider the security implications in the event of key theft?
K9F wrote:
By combining your key and 10as fob into one convenient unit you are effectively removing a potential security layer on your Defender. The 10as fob should in theory never be kept on the same keyring as your key. Lose one or the other your Defender still has a layer left, lose the combined unit and it's self explanatory. The most basic principles of security are quite often overlooked for convenience. With the increase reported in burglaries and the associated theft of keys why make it easier for them?
Just my 2 pennethworth. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #434156 27th Jun 2015 11:29pm
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Although I agree with your point. How many people actually keep them separate? My guess is very, very few.
I have enough trouble finding one set of keys, let alone two. They are of course always where I left them!! Very Happy Very Happy
Post #434182 28th Jun 2015 7:22am
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Any interest out there in getting another group together for more fobs?
Post #445087 11th Aug 2015 5:24am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
I am interested in this for my 110. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #446373 15th Aug 2015 8:08pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Count me in please.
Post #446374 15th Aug 2015 8:16pm
