Home > Puma (Tdci) > Puma 2.2 Compatible Oils |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Due to another discussion surrounding the limited availability of correct oil for the Puma 2.2 below is a list of oil that meets the requirement of Ford's WSS-M2C-934-B Standard.
NOTE! - This is only applicable to 2.2 Pumas as the earlier 2.4 needs to have the widely available WSS-M2C913-B (or C) standard All these oils are available in 5W30; Liqui Molly Top Tec 4500 Millers XF Longlife C1 Shell Helix Ultra Professional Shell Helix Diesel Ultra Motul 8100 Eco-Clean+ Mobil Super 3000 Formula C1 Granville FS-M Castrol Edge Professional C1 Valvoline SynPower ENV C1 Pro Advance PC1050 Fuchs Titan GT1 PRO C-1 Gulf Formula EFE Carlube Triple R Longlife Fully Synthetic C1 Comma Ecolife IADA Linus Fully sinthetic C1 AD SC1 Cepsa XTAR ECO TECH CRTD C1 MOTOREX CONCEPT X-C1 CHAMPION OEM SPECIFIC C1 Remember when buying these oils to confirm that they are indeed to the WSS-M2C-934-B standard. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography Last edited by x-isle on 16th Jan 2015 1:21pm. Edited 3 times in total |
16th Jan 2015 11:59am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6603 |
At the bottom I think you mean 934-B
And add http://www.advancedfactors.co.uk/pc1050-5w...2412-p.asp Few more missing which are on this list: http://www.disco3.co.uk/forum/post1007004.html#1007004 1988 90 Td5 NAS soft top 2015 D90 XS SW |
16th Jan 2015 12:07pm |
Damn it, I did it again (cut and paste error)!
Corrected now and updated the list to include those others Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
16th Jan 2015 12:09pm |
Boris Member Since: 02 May 2014 Location: Oswestry Posts: 21 |
I've put some of this http://www.halfords.com/motoring/engine-oi...il-5l#tab2 In my 2014 puma , I'm guessing after reading this it's the wrong stuff ?
If it is halfords want shooting ! |
15th Feb 2015 8:11pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
No good for your Puma!
You need an oil with an ACEA 'C' category ... The one you used is only a 'B' Guns and Landrovers .... anything else is irrelevant. |
15th Feb 2015 9:49pm |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1641 |
Interesting, thanks!
Do you happen to know exactly what (Make/type etc) oil they fill the 2.2 Puma with at the Factory? Cheers, Pete YOLO... You Only Live Once... |
16th Feb 2015 8:55am |
BUMP????? YOLO... You Only Live Once...
28th Feb 2015 11:02am |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Hi Yolo
The oil spec for the engine is: 5W/30 to ford spec WSS–M2C934–B Shell: http://www.shell.co.uk/gbr/products-servic...-5w30.html Mobil: http://www.mobil.com/UK-English/Lubes/PDS/...5W-30.aspx Castrol: http://msdspds.castrol.com/bpglis/FusionPD...9TBLG7.pdf Are a few that meet the requirements. Not 100% sure of the make that they will use in the factory, no doubt it will be bought in bulk and will be budget driven. Hope this helps John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
28th Feb 2015 11:21am |
Hi John!
BUMP works!!! Many thanks... that is useful. I wanted to use the same make of oil that was first used at the factory... probably Castrol according to my local stealer! I guess I am 'guilty' of being OTT about this! Oil (to the right spec!) is oil!!! And after all, there are thousands of Ford Transit vans being thrashed about the place using probably 'Fish and Chip' oil in the UK!!! I was planning an oil and filter change on my new Defender earlier than 20k km's... once agin, this is probably overkill! Makes one feel better... maybe! Cheers, Pete :>) YOLO... You Only Live Once... |
28th Feb 2015 11:32am |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 407 |
Does anyone know where I can source the right spec oil in Italy?
Will buying it from the dealer be more expensive? Thanks |
9th Jun 2015 3:44pm |
Understand the Puma 2.2 has to have this ....934-B oil spec, but can that same oil be safely used also in a Puma 2.4? Meaning can the Puma 2.4 be fed either of those oils, the one specified for it, as well as the one discussed here for the newer Puma 2.2? Wonder if all dealers will have barrels of both in stock at all times, or if they use the same for both engines. If you add to this all the oils specified for the other Td5, FFRR, RRS, D4, D3, Freelanders, Eewoks, etc. and their different aged engines they regularly get in their workshop, a main dealer must have a small oil tank farm on his premises. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
9th Jun 2015 4:32pm |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
The main difference between 2.4 and 2.2 oil is the low "sap" rating something to doings with soot in the dpf. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
9th Jun 2015 6:10pm |
Can someone help me with the part number for the oil filter? I have searched Google to no avail.
Vehical is 2015 Thanks |
21st Jun 2015 3:40pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20294 |
I used to run Edge but now on Helix as per dealer use.
Seems better, but then it's been tuned since. It does seem smooth though. |
21st Jun 2015 3:50pm |
