Home > Puma (Tdci) > Puma 2.2 Compatible Oils
Page 1 of 5 12345>
x-isle
Due to another discussion surrounding the limited availability of correct oil for the Puma 2.2 below is a list of oil that meets the requirement of Ford's WSS-M2C-934-B Standard.
NOTE! - This is only applicable to 2.2 Pumas as the earlier 2.4 needs to have the widely available WSS-M2C913-B (or C) standard
All these oils are available in 5W30;
Liqui Molly Top Tec 4500
Millers XF Longlife C1
Shell Helix Ultra Professional
Shell Helix Diesel Ultra
Motul 8100 Eco-Clean+
Mobil Super 3000 Formula C1
Granville FS-M
Castrol Edge Professional C1
Valvoline SynPower ENV C1
Pro Advance PC1050
Fuchs Titan GT1 PRO C-1
Gulf Formula EFE
Carlube Triple R Longlife Fully Synthetic C1
Comma Ecolife
IADA Linus Fully sinthetic C1
AD SC1
Cepsa XTAR ECO TECH CRTD C1
MOTOREX CONCEPT X-C1
CHAMPION OEM SPECIFIC C1
Remember when buying these oils to confirm that they are indeed to the WSS-M2C-934-B standard. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #389011 16th Jan 2015 11:59am
Martin
Site Admin
At the bottom I think you mean 934-B Whistle
And add http://www.advancedfactors.co.uk/pc1050-5w...2412-p.asp
Few more missing which are on this list: http://www.disco3.co.uk/forum/post1007004.html#1007004  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #389015 16th Jan 2015 12:07pm
x-isle
Damn it, I did it again (cut and paste error)!
Corrected now and updated the list to include those others Craig Rogers
2007 Puma 110 XS
Post #389016 16th Jan 2015 12:09pm
Boris
I've put some of this http://www.halfords.com/motoring/engine-oi...il-5l#tab2 In my 2014 puma , I'm guessing after reading this it's the wrong stuff ?
If it is halfords want shooting !
Post #399118 15th Feb 2015 8:11pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
No good for your Puma! Shocked
You need an oil with an ACEA 'C' category ... The one you used is only a 'B' Guns and Landrovers .... anything else is irrelevant.
Post #399162 15th Feb 2015 9:49pm
Boris
Ok thanks for that , halfords are a shower of $hite (no surprises there !) if you type the reg of your puma or put the model in , it says you need this stuff Big Cry
Post #399214 16th Feb 2015 6:33am
YOLO110
Australia
Interesting, thanks!
Do you happen to know exactly what (Make/type etc) oil they fill the 2.2 Puma with at the Factory?
Cheers,
Pete Smile YOLO... You Only Live Once...
Post #399231 16th Feb 2015 8:55am
YOLO110
Australia
BUMP????? Shocked YOLO... You Only Live Once...
Post #402997 28th Feb 2015 11:02am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Yolo
The oil spec for the engine is:
5W/30 to ford spec WSS–M2C934–B
Shell: http://www.shell.co.uk/gbr/products-servic...-5w30.html
Mobil: http://www.mobil.com/UK-English/Lubes/PDS/...5W-30.aspx
Castrol: http://msdspds.castrol.com/bpglis/FusionPD...9TBLG7.pdf
Are a few that meet the requirements.
Not 100% sure of the make that they will use in the factory, no doubt it will be bought in bulk and will be budget driven.
Hope this helps
John Thumbs Up 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #403003 28th Feb 2015 11:21am
YOLO110
Australia
Hi John!
BUMP works!!!
Many thanks... that is useful. I wanted to use the same make of oil that was first used at the factory... probably Castrol according to my local stealer!
I guess I am 'guilty' of being OTT about this! Oil (to the right spec!) is oil!!! And after all, there are thousands of Ford Transit vans being thrashed about the place using probably 'Fish and Chip' oil in the UK!!!
I was planning an oil and filter change on my new Defender earlier than 20k km's... once agin, this is probably overkill!
Makes one feel better... maybe!
Cheers, Pete :>) YOLO... You Only Live Once...
Post #403008 28th Feb 2015 11:32am
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Does anyone know where I can source the right spec oil in Italy?
Will buying it from the dealer be more expensive?
Thanks
Post #429760 9th Jun 2015 3:44pm
ericvv
Re: Puma 2.2 Compatible Oils
Understand the Puma 2.2 has to have this ....934-B oil spec, but can that same oil be safely used also in a Puma 2.4?
Meaning can the Puma 2.4 be fed either of those oils, the one specified for it, as well as the one discussed here for the newer Puma 2.2?
Wonder if all dealers will have barrels of both in stock at all times, or if they use the same for both engines. If you add to this all the oils specified for the other Td5, FFRR, RRS, D4, D3, Freelanders, Eewoks, etc. and their different aged engines they regularly get in their workshop, a main dealer must have a small oil tank farm on his premises.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #429771 9th Jun 2015 4:32pm
noworries4x4
The main difference between 2.4 and 2.2 oil is the low "sap" rating something to doings with soot in the dpf. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #429793 9th Jun 2015 6:10pm
Yannis
Can someone help me with the part number for the oil filter? I have searched Google to no avail.
Vehical is 2015
Thanks
Post #432574 21st Jun 2015 3:40pm
I used to run Edge but now on Helix as per dealer use.
Seems better, but then it's been tuned since.
It does seem smooth though.
Post #432578 21st Jun 2015 3:50pm
Page 1 of 5 12345>
