![]() | Home > Technical > brake union advise please |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
Yes, anti-roll bars in my opinion are a worthwhile investment and do help with the handling. I have them fitted on both my Defenders. Rear disk brakes are also a good investment I have always thought that disk brakes provide a distinct advantage over drums and brake shoes in wet weather braking. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
The brake pipe will be 3/16". Brake unions should be 3/8" on early models and 10mm after that although I don't know when the change was implemented. The fittings on my donor axles (1996 Disco) were definitely metric.
HTH Harry |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6642 ![]() ![]() ![]() |
All Defenders/90/110/127/130 are metric brake line fittings. Discos used imperial up to about 1994 I think.
trickymicky Member Since: 18 Jan 2014 Location: nottingham Posts: 8 ![]() ![]() |
I suppose that if the calipers have metric fittings I can continue making the rest in metric. Would the master cylinder be metric or are they all imperial ?
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
I have just changed my axles to discovery ones, found to calipers where the same on the front axles! Just different pads which was handy as the donor axles had a leak caliper. New axles alot quieter.
