![]() | Home > Wheels & Tyres > steel wheel |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
i am thinking of a second set of steel wheel with M/T tyres.
what i do like is this type of wheel(with Sand Blasted and painted white ) http://cgi.ebay.co.uk/range-rover-classic-...4cf1796051 (ok i know, i am ill but i do treat ![]() does anyone know if i can put 285/75/16 tyre to this wheel ? www.newfoundland.gr |
I wouldn't fit that size to that rim
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 ![]() ![]() ![]() |
Pouf these are ANR4635 Rostyle tubed 6,0Jx16 ET 33, too tight for 285.... Matteo
Defender 110 Td4 SE MY 09 |
i want this size 285/75/16 because diameter is 3 cm bigger than 7.50R16 ( 83,4 cm - 80,2 cm) and i think it is the simplest way to increase the distance between the ground and the center differential.( i don't like the idea of coil and suspension because i have heard about problems with noise and bumps)
as i can see i have to find other type of wheel ![]() -mateo force domani andremo per le passeggiate e mangiare ![]() ![]() Se si � disponibili..................... www.newfoundland.gr |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2463 ![]() ![]() ![]() |
Too narrow for 285s Puma 110" SW
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
... and it will make a diference on your speed reading, and reduce your turning circle if (maybe) they rub your suspension arms. it happened to me with a set of General SAG 7.50/16 - which were the correct measure for the Defender-so I had to limit the turning circle Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
so, any suggestions? www.newfoundland.gr
To be on the safe side get some modular steel rims (7-8" wide). Puma 110" SW
Ah parli anche italiano!!molto bene ![]() Purtroppo il sabato lavoro fino alle 4,00 pm, se andate pi� tardi (ma non penso...) ci vengo molto volentieri!! Unfortunately saturday I work up to 4,00 pm, if you go later (but I don't think so...) I come very gladly!! ![]() Defender 110 Td4 SE MY 09 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8206 ![]() ![]() ![]() |
255.85s on a 1 7J rim. they will go on wolf rims too which are nice and strong. Cheers
255's are a very good choice but it may need a lift to stop rubbing. The steel wheels are not rated for 110 but ok for 90's
- mateo , va be, un altra volta. tomorrow we'll start at 11.00 am
-james, wolf is a wheel that i am thinking of(i like white) www.newfoundland.gr |
which steel wheels arent rated for 110s? Wolf wheels are i believe. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
The Range Rover Rostyles in the original eBay ad aren't rated for 110s. Peter
2008 SWB Truck Cab 1952 80" Soft top |
