Home > Wheels & Tyres > steel wheel
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
steel wheel
i am thinking of a second set of steel wheel with M/T tyres.
what i do like is this type of wheel(with Sand Blasted and painted white )
http://cgi.ebay.co.uk/range-rover-classic-...4cf1796051
(ok i know, i am ill but i do treat Laughing )
does anyone know if i can put 285/75/16 tyre to this wheel ? www.newfoundland.gr
Post #40251 10th Sep 2010 7:51am
110SEB
On the basis that it has a 16 inch tyre on it already, your 16s would fit.
You need to be sure about weight rating of the wheel to be able to carry your Defender. I don't know much about RRCs other than they look cool.
Thumbs Up
Post #40253 10th Sep 2010 8:40am
I wouldn't fit that size to that rim
Post #40254 10th Sep 2010 8:42am
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Pouf these are ANR4635 Rostyle tubed 6,0Jx16 ET 33, too tight for 285.... Matteo
Defender 110 Td4 SE MY 09
Post #40255 10th Sep 2010 8:43am
pouf
i want this size 285/75/16 because diameter is 3 cm bigger than 7.50R16 ( 83,4 cm - 80,2 cm) and i think it is the simplest way to increase the distance between the ground and the center differential.( i don't like the idea of coil and suspension because i have heard about problems with noise and bumps)
as i can see i have to find other type of wheel Sad
-mateo force domani andremo per le passeggiate e mangiare Very Happy Very Happy .
Se si � disponibili..................... www.newfoundland.gr
Post #40258 10th Sep 2010 9:15am
MK
Too narrow for 285s Puma 110" SW
Post #40259 10th Sep 2010 9:15am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
... and it will make a diference on your speed reading, and reduce your turning circle if (maybe) they rub your suspension arms. it happened to me with a set of General SAG 7.50/16 - which were the correct measure for the Defender-so I had to limit the turning circle Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #40262 10th Sep 2010 9:24am
pouf
so, any suggestions? www.newfoundland.gr
Post #40263 10th Sep 2010 10:02am
MK
To be on the safe side get some modular steel rims (7-8" wide). Puma 110" SW
Post #40266 10th Sep 2010 10:14am
Bomber82
Ah parli anche italiano!!molto bene Wink
Purtroppo il sabato lavoro fino alle 4,00 pm, se andate pi� tardi (ma non penso...) ci vengo molto volentieri!!
Unfortunately saturday I work up to 4,00 pm, if you go later (but I don't think so...) I come very gladly!! Thumbs Up Matteo
Post #40269 10th Sep 2010 11:50am
jst
255.85s on a 1 7J rim. they will go on wolf rims too which are nice and strong. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #40271 10th Sep 2010 12:20pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
255's are a very good choice but it may need a lift to stop rubbing. The steel wheels are not rated for 110 but ok for 90's
Post #40272 10th Sep 2010 1:05pm
pouf
- mateo , va be, un altra volta. tomorrow we'll start at 11.00 am
-james, wolf is a wheel that i am thinking of(i like white) www.newfoundland.gr
Post #40273 10th Sep 2010 1:16pm
jst
which steel wheels arent rated for 110s? Wolf wheels are i believe. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #40285 10th Sep 2010 3:53pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
The Range Rover Rostyles in the original eBay ad aren't rated for 110s. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #40289 10th Sep 2010 4:50pm
