Home > Puma (Tdci) > Mounting back the self adjusting brake pedal sensor |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 |
Didn't think they were self adjusting. Just a simple on / off in a single position?
21st Feb 2015 5:18pm |
Harald Member Since: 30 May 2012 Location: Flanders Fields Posts: 81 |
They are self adjusting, it also says so in the manual, but the manual doesn't tell how to mount them
21st Feb 2015 5:38pm |
normally pull the centre pin out , they normally on like a ratchet on the pin
21st Feb 2015 5:42pm |
Munch 90, thnx, the centre pins are completely out.
If you disassemble them they go completely forward. My guess is I made the mistake to put the brake pedal down to make it more easy to mount the switches back. If yoy turn them to mount the centre pin goes to much forward and thinks that the starting point. I mounted them again with the brake pedal not pressed. I think that is the most logical way to 'start' the self adjusting...............when you turn them they 'self adjust. Tomorrow I will check if that was the right way |
21st Feb 2015 6:02pm |
Yes the centre pin comes out when you remove from the pedal , but on most modern brake light switches the centre pin is on a ratchet and you pull the centre pin out , then fit the switch with the pedal pushed down then release the pedal slowly to set the switch
21st Feb 2015 7:09pm |
Didn't know that |
21st Feb 2015 8:37pm |
OK, the correct way to do it is:
1) Don't touch the brake pedal. 2) Mount the brake light switch and brake pedal sensor and turn 45 degrees to fasten. 3) Operate the brake pedal and check if the brake lights go on/off at the right time. That's all, but you just have to know it PS This procedure seems to be different from the procedure for a Discovery or Range Rover Sport. |
23rd Feb 2015 1:03pm |
