Home > Puma (Tdci) > Mounting back the self adjusting brake pedal sensor
Harald
Belgium 2010 Defender 90 Puma 2.4 Fire LE Vesuvius Orange
Does anybody know how to mount the brake light sensor and brake pedal sensor back?
They are self adjusting.
Do I need to push the panel to the bottem when I mount these sensors, or it it just the opposite?
Post #400882 21st Feb 2015 5:15pm
Caterham
Didn't think they were self adjusting. Just a simple on / off in a single position?
Post #400883 21st Feb 2015 5:18pm
Harald
They are self adjusting, it also says so in the manual, but the manual doesn't tell how to mount them Sad
Post #400893 21st Feb 2015 5:38pm
munch90
normally pull the centre pin out , they normally on like a ratchet on the pin
Post #400894 21st Feb 2015 5:42pm
Harald
Munch 90, thnx, the centre pins are completely out.
If you disassemble them they go completely forward.
My guess is I made the mistake to put the brake pedal down to make it more easy to mount the switches back.
If yoy turn them to mount the centre pin goes to much forward and thinks that the starting point.
I mounted them again with the brake pedal not pressed.
I think that is the most logical way to 'start' the self adjusting...............when you turn them they 'self adjust.
Tomorrow I will check if that was the right way Rolling Eyes
Post #400904 21st Feb 2015 6:02pm
munch90
Yes the centre pin comes out when you remove from the pedal , but on most modern brake light switches the centre pin is on a ratchet and you pull the centre pin out , then fit the switch with the pedal pushed down then release the pedal slowly to set the switch
Post #400939 21st Feb 2015 7:09pm
Caterham
Shocked
Didn't know that
Thumbs Up
Post #400978 21st Feb 2015 8:37pm
Harald
OK, the correct way to do it is:
1) Don't touch the brake pedal.
2) Mount the brake light switch and brake pedal sensor and turn 45 degrees to fasten.
3) Operate the brake pedal and check if the brake lights go on/off at the right time.
That's all, but you just have to know it Razz
PS This procedure seems to be different from the procedure for a Discovery or Range Rover Sport.
Post #401387 23rd Feb 2015 1:03pm
