Home > Maintenance & Modifications > any link between no filler cap and engine warning light?...
X4SKP
Hi All
Can I get your advice...?
Filled the Defender with Diesel today and drove off without replacing the filler cap...(I know... Embarassed )
Within 5 miles, still unaware that I had not replaced the Cap the Engine Warning Light came on...
reduced speed immediately (on Motorway) left within 2 miles to a Service Station to check things.
After around 5-10 minutes, checked the Oil and no change from 2/3 up the hatched section of the dip stick.
My Defender was fully serviced 300 miles ago, all oils, all filters.
It runs apparently fine, no change in engine temp, no noises (other than the ordinary)
crawled home runs just as normal no smoke stills pulls as normal. But something is not right.
Then noticed the Filler Cap (or lack of it)... are they linked?
Does the Tank get 'pressurised' and therefore it dropped and the Engine sensed this and gave its warning?
Is this an ECU code process from now on?
Any wisdom from you would be appreciated... thanks
 SKIP
Post #399116 15th Feb 2015 8:01pm
munch90
Cant see there being any link , unless a load of water/rain went in
i forgot cap once done quite a few miles no problem
Post #399122 15th Feb 2015 8:39pm
Venomator
Mine came on earlier in the week, coinciding with finding the bonnet had popped for some reason... Shocked
Cleared the Fault Code and it has not returned, yet... Whistle
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #399127 15th Feb 2015 8:58pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Was mortified to find I'd been driving for about two days around Devon with my fuel cap off (but tethered).
(I'm a bike rider and know how lethal spilt diesel is).
No ill effects on the USW though. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #399147 15th Feb 2015 9:15pm
X4SKP
Thanks guys,
munch90
No rain during this 'episode' so i'm sure that water in the fuel tank is not a factor.
Macpaul
Level and gentle progress after leaving the petrol station also, no diesel 'residue / film'
on the side of the Defender, so luckily I'm sure I haven't added to the risks of riding a motorbike
(me too Macpaul, GS1200 Tyres + Diesel = Evil or Very Mad )
Venomator
Cleared the Fault Code and it has not returned yet... I have seen the Fault Code diagnosis issue and 'Testers' covered on here so am about to read up on these. As I'v gone form a 300tdi to a 2.4puma I guess it's the price you pay for an ECU and a bit of electrickery... If there's a problem first I want to know what it is, code meaning, I guess, then check / fix issue before 'cancelling' the Engine Warning Light...I guess also that it is possible to get a false error messages Question
So my question at this point is what have you got ? and how (in general terms) do you use it.
Thanks. SKIP
Post #399252 16th Feb 2015 10:45am
Venomator
Hiya Skip...
I have an Ultra Guage permanently fitted, so...
Allows visibility, and clearance, of Fault Codes - the FC I had last week was P1103...
Which, on investigation here on D2, means, according to Mal (@K9F) - P1103 is a 'nuisance code' that will invariably reset after a few driving cycles. If it persists then look at a MAF but at your stage I wouldn't be overly concerned. Numerous threads about it if you do a search under 'P1103.'
So, I reset it with the UG and it hasn't re-appeared, yet... Whistle
 Rog... Mr. Green
The GREEN One...
Post #399254 16th Feb 2015 11:02am
K9F
Bang on the money Venomator. P1103 'Mass Air Flow Sensor In Range But Higher Than Expected.' Nuisance code is all it is. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #399257 16th Feb 2015 11:08am
X4SKP
Venomator and K9F
Thanks for the quick reply you two, much appreciated, I will read up and decide what route to go down.
In principle am I right in assuming that this symbol...
Means that you have a potential problem now check the relevant code... Question
i.e no other lights on the dashboard... that signal the Engine Management ECU has a problem... Question
The other lights are just sensors on the relevant items, handbrake, battery charging (alternator)
heating coils for ignition, oil level / temp (don't know if it is both) ABS... etc Question
Thanks. SKIP
Post #399268 16th Feb 2015 11:35am
Venomator
Yes Skip, that will be absolutely correct, unless it coincides with the Engine going into 'Limp' mode as well, in which case you might deduce there could be something worth more urgent investigation going on!... Thumbs Up
All part of the reason I picked up the Ultra Guage... Mr. Green
Although other (Scan) Guages are available... Whistle
 Rog... Mr. Green
The GREEN One...
Post #399274 16th Feb 2015 12:02pm
K9F
From another thread which is quite old.......
K9F wrote:
Loads on here using 'Scangauge' as the keyword...... Thumbs Up
K9F wrote:
Pound for pound and with what you want it to do Scangauge in my opinion is the best. Had one know for a couple of years or so and it does everything I want it to do.....
http://www.defender2.net/forum/topic4510.html?highlight=scangauge
Lorryman and ofourdan agree too that it is best value....
http://www.defender2.net/forum/topic9642.html?highlight=pound
If I were to choose now I would also look closely at the Ultragauge as that too has had good reviews. The binnacle modification is a winner too for the Ultragauge. My Scangauge sits on my rear view mirror out of the way but convenient when I need it on a Blendmount Kit. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #399281 16th Feb 2015 12:19pm
X4SKP
Thanks Venomator... Thumbs Up
Just read that K9F looks to be using the ScanGauge II so that's on my 'to understand more list'
zone30 appears to have the UltraGauge too
...my natural inclination is to
a. understand it
and
b. try and be self sufficient
A good Fault Diagnosis System and Reset Facility is my first requirement but a Trip Computer
with various Operating Parameters may join in, if it doesn't over complicate things.
again thanks. SKIP
Post #399286 16th Feb 2015 12:31pm
X4SKP
K9F ... you got there first... thanks for your help on this... Thumbs Up SKIP
Post #399287 16th Feb 2015 12:33pm
Venomator
I think you will find that the Ultra Guage (for sure!) and the Scan Guage will offer the Trip Computing and other functionality you may be looking for... Thumbs Up
Ultra Guage < Linky ... Wink
Scan Guage < Linky ... Razz
There is also a stack of info here on D2 Dot Net for both on a search... Mr. Green  Rog... Mr. Green
The GREEN One...
Post #399289 16th Feb 2015 12:38pm
K9F
Skip,
You have a 'pm.' Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #399291 16th Feb 2015 12:40pm
X4SKP
Thanks for the help on this...
Read up a decided to go with the ScanGauge as a Diagnostic Tool (when needed)
but also getting real time monitoring of a host of other stuff when hooked up.
But I'm sure my Defender has a mind of it's own, Parcel arrived this morning
went down to fit it checking the Defender in the workshop and...no warning light Exclamation
I'm happy about this and it looks as though I can retrieve historical Fault Codes
even when cleared. I realise that some MIL / Engine Warning Lights problems
'reset' themselves after a number of running cycles...mine has had about 6 but
it felt slightly more than a coincidence... Shocked
 SKIP
Post #400986 21st Feb 2015 8:59pm
