Home > Puma (Tdci) > Exhaust smell in cabin?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all...
For the past week or so I've been experiencing an exhaust smell in the cabin, about a minute or two after I set off down the road. After another minute or two it dissipates.
Checked to see if I could see anything leaking under the bonnet, like the yellow quick valve thing, but that looks OK.
Thought maybe the rear door has a gap or something and the gas is getting sucked in as I drive, but again don't see anything of this nature either.
Anyone else ever experience this? Any suggestions where I might be able to check further?
Thanks!
Post #398674 14th Feb 2015 9:20am
munch90
manifold gasket , turbo gasket , egr valve ?
Post #398675 14th Feb 2015 9:28am
ibexman
Centre box?
Post #398681 14th Feb 2015 9:48am
eutek
Super - thanks
Post #398697 14th Feb 2015 10:51am
JWL
Just check down in the passenger footwell on the vertical slope to see if the rubber bung hasn't come out. It can give you a whiff of exhaust gas at start up if the exhaust manifold/downpipe to turbo gaskets are old and leak a little on start up untill they get warm.
Post #398698 14th Feb 2015 10:56am
eutek
Turns out that the back door had shifted slightly, the upper left-hand corner wasn't even touching the seal anymore.
Time for a Mantec wheel carrier I think...
Post #419829 28th Apr 2015 7:12pm
