Home > Td5 > Overheated 1999 TD5
Page 2 of 2 <12
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
Thanks for the reply Iain_s that's pretty much the situation I'm at now, tomorrow im going to start ordering bits and just get it changed before anymore damage is done to more expensive bits.
Post #396450 6th Feb 2015 5:42pm
ttuck3r
Right so I've taken the head off and replaced head gasket with new one, the old one didn't look bad at all, new steel dowels as the plastic ones where all bent, new injector seals, water pump and thermostat, got her running and brought her up to temp put the computer on and revved her up to get the thermostat open and it still hadnt moved at 92 degrees, is it possible the new stat is guff?
Post #398276 12th Feb 2015 9:34pm
Laurie
Did you check the flow through the radiator while the head was off?
Post #398286 12th Feb 2015 10:00pm
ttuck3r
Well I think that's all sorted, today the radiator got checked, put it all back together with new thermostat, then I filled the system up, started her, knocked up the RPMs to 2900 and sat for 45 min watching bubbles slowly working out the system whilst topping up, then right at the end a series of bubbles came gurgling out and all the hoses warmed up, what a pain in the arse.
Post #398626 13th Feb 2015 11:54pm
Page 2 of 2 <12
