Home > Td5 > Overheated 1999 TD5 |
The reaction off your gauge is normal. It will never go slowly up. it sits at normal temperature and jumps to full in the red when hot. (At least mine does that too when trying to get out deep mud after a while) Roel
31st Jan 2015 9:09pm |
Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98 |
Let's hope it's nothing serious like the head or gasket .
My thought could be an air lock as you've just changed the thermostat ? Good luck. |
31st Jan 2015 10:35pm |
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 |
O well today it happened all again except this time it blew the expansion bottle lid off and dumped water out the bottle and some around the thermostat area maybe the radiator not to sure yet.. still hoping its water pump..
1st Feb 2015 9:33pm |
Make sure you get all the air out the system. A td5 is not the easiest engine for that. Roel
2nd Feb 2015 8:24am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6105 |
Sounds like head gasket or warped head.
My old 90 did this... only when i "booted it" and got the engine hot. |
2nd Feb 2015 9:21am |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 |
Sounds like head gasket or head I had the same problem just over a year ago, fitted a new Spanish head
2nd Feb 2015 10:54am |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 158 |
sounds like the water pump has disintegrated.
Try that first, before going down the route of the head. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
2nd Feb 2015 4:27pm |
Thanks for the replies lads, tomorrow I'm pulling the water pump off and fitting a new one, let's cross fingers.
2nd Feb 2015 8:47pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
I had similar issues with a V8 I owned years ago water pump had no play in it but when I pulled it off the impeller had come off the shaft ! Being hard up at the time I welded it back on instead of buying a new pump.
Hope it turns out to be a cheap fix for you 2005 Td5 90 XS Steve |
2nd Feb 2015 8:53pm |
Water pump was not the issue, took off the old one and it's in better condition then the new one, I have now taken it down to the mechanics and tested for everything with no apparent issues, the mechanic seems to think it could be a faulty expansion bottle cap so a new one is on order.
Seriously Confused!!! |
4th Feb 2015 8:50pm |
As your car is at your mechanics see if he can do a sniffer test to check for combustion gasses in the cooling system. 2005 Td5 90 XS
Steve |
4th Feb 2015 8:56pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
I carried out sniffer test on my old td5 and showed no sign of contamination, symptoms as above.
Ended up pulling the head off, and the plastic locating dowels had sheared off causing the head to move, same problem on early freelanders, also on early td5s mine was 52plate If you do end up doing the head gasket, get the metal dowels 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
4th Feb 2015 9:06pm |
I give up, I've now had my Landy at 2 different shops, with me telling them to check the head and to give me a price to do the head gasket, and both of them laughing me out the door with there diagnoses of the problem. Might have to attempt this myself.
5th Feb 2015 9:50pm |
Iain_S Member Since: 03 Sep 2014 Location: West Lothian Posts: 8 |
Mine was like this for months, just temp gauge going into the red and sometimes blowing out coolant. Temp gauge went back to normal if I eased off a bit. It finally got worse, so tha I had to top up coolant every 50 miles or so.
I finally changed the head gasket. The old one had delaminated along the exhaust manifold side. Only explanation I can think of was that the head bolts had lost some elasticity, and had stretched. They were certainly VERY easy to undo, in contrast to the sweat that went into getting the last 45 degrees on the new ones! |
6th Feb 2015 1:13pm |
