![]() | Home > Puma (Tdci) > Thoughts on servicing interval? |
Davefarmer Member Since: 29 Dec 2014 Location: Norfolk Posts: 19 ![]() ![]() ![]() |
If it was me I'd keep it under cover, every now n then run the engine to keep the oil all round the engine and get it up to temperature
It's similar to my combine harvester, it gets 50hours a year in work rest of the time it's stood up, I change the oil and filters every other year seams fine. Use good quality oil wouldn't of thought you will get any problems, keep close eye on the quality of your antifreeze and brake fluid, |
There is a good thread on here or lr4x4 listing fully synthetic alternatives, I changed mine every 2years
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
There's some interesting info in this thread http://www.defender2.net/forum/topic31599....e+interval
There is a report in the thread that states NOT changing oil so often is no bad thing. It's very confusing as to what is best and much of it is counter-intuitive. Cheers Simon |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
My Puma does around the same mileage these days, perhaps slightly more (3000), I still change the oil and filters every 12 months regardless. For what it costs to do it (£60-£80) it's not breaking the bank.
Plus when it comes to ever letting it go, I have a history (albeit self servicing) of recommended intervals. Oil can "go off" as it can breakdown/oxidise even when not used so still good to give it a change. Some people say that it's not good for environment to change it when it's not used but if you recycle it properly (local waste station) then it gets turned to heating oil. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
oil and oil filter would not be my first thing to worry about
fuel filter , bacteria growth in diesel if sitting about a long time brakes , pistons seizing etc general items seizing up , prop uj's , steering uj's , I don't tend to service regularly at a certain date etc , more when I feel like it , but normally before long trip ( holiday etc ) which is roughly once a year |
![]() That's the good thing with self-servicing, things can be done when you need to do them. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
General Grabber Member Since: 27 Dec 2013 Location: Mos Eisley Posts: 49 ![]() |
Thanks all,
Lots of interesting opinions and some conflicting information too. The case for NOT changing the engine oil too often does seem quite strong, however I appreciate that fuel filters should probably be changed more regularly. My vehicle will still be driven regularly, as opposed to being laid up for long periods, so it will still have regular use throughout the year, but just not covering very many miles in total. So I'm hoping that things like seized pistons and brakes should not be a problem. Can anyone suggest the recommended service intervals for brake fluid and anti-freeze as these seem to be more important to change regularly? Thanks again. |
recommended service interval for brake fluid = 2 years
recommended service interval for anti-freeze = 10 years |
Thanks Supacat.
Much appreciated. |
