Home > Puma (Tdci) > Oil leak...Gearbox? |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
What colour was the oil before you degreased it?
From that area I would most likely suspect its rear main oil seal on back of the engine block. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
7th Feb 2015 5:49pm |
I-Landy Member Since: 28 Jan 2015 Location: Bournemouth Posts: 35 |
Like a browny colour I think...
7th Feb 2015 6:41pm |
Today's update after a short drive:
Click image to enlarge Looks a lot like a gasket/seal to me-note fresh oil around the gearbox/engine seam compared with photo yesterday. How bad is this?!! |
8th Feb 2015 10:57am |
If you're local to Alder Hills whip it in here and get an expert opinion. Cost you nowt but a little time perhaps.
http://www.bournemouthlr.co.uk/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
8th Feb 2015 11:05am |
Thanks K9F,
Tomorrow? What time you open from? Cheers |
8th Feb 2015 11:38am |
I wish.....when referring to 'here' I meant the link, not the fact it belongs to me. Not mine, but one I have visited. Turn in by the Macdonalds onto the industrial estate, first right, then left, it's the last unit on the right hand side. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
8th Feb 2015 11:44am |
Ha! I thought it was a brave business move, but now that makes more sense. I'll try them. Thanks for the link.
8th Feb 2015 12:00pm |
Let us know how you get on. If you go through life with your head in the sand....all people will see is an ar5e!!
8th Feb 2015 12:01pm |
Apparently it's Clutch Slave Cylinder. Gearbox out job is what I've been told. Ouch! 😳
9th Feb 2015 2:52pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17212 |
While the box is out, get them to inspect and lubricate the gearbox output adaptor shaft splines. You'll probably also want to consider a new driven plate (even if the old one isn't contaminated with fluid) since they have a very limited life before the springs take on a permanent set.
9th Feb 2015 3:29pm |
The garage has suggested a new clutch whilst the box is out. I didnt realise the slave cylinder was such a big job! Got to be done though...
9th Feb 2015 4:17pm |
Can be done at home with the right time, a little help and tooling.....
Be interested to know how much he has quoted as a guideline. There is also AL Services in Poole. You could give them a call for a quote perhaps and see who comes out on top? I don't own or work at this one either...... http://www.alservices.co.uk/about/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
9th Feb 2015 4:40pm |
It isn't a big job, it just requires removing the gearbox! I suppose it depends how you define "big" though! |
9th Feb 2015 5:19pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2395 |
Gearbox and engine oil smell very different so get some engine oil from your engine and compare. Viscositywise is hard to tell. Puma 110" SW
9th Feb 2015 11:49pm |
