Home > Puma (Tdci) > Oil leak...Gearbox?
I-Landy
United Kingdom 2007 Defender 130 Puma 2.4 HCPU Baltic Blue
Oil leak...Gearbox?
I have a 2007 def 130 hiCap, noticed a smell of oil recently after a few longer journeys, a couple of motorways runs included. There appears to be a leak around the engine side of the gearbox. Here is a pic of the cleaned up and degreased suspect area.
Any thoughts on what it is? Gasket?
What do I do? 😳
Post #396684 7th Feb 2015 4:08pm
shaggydog
What colour was the oil before you degreased it?
From that area I would most likely suspect its rear main oil seal on back of the engine block. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #396701 7th Feb 2015 5:49pm
I-Landy
Like a browny colour I think...
Post #396713 7th Feb 2015 6:41pm
I-Landy
Today's update after a short drive:
Looks a lot like a gasket/seal to me-note fresh oil around the gearbox/engine seam compared with photo yesterday. How bad is this?!!
Post #396926 8th Feb 2015 10:57am
K9F
If you're local to Alder Hills whip it in here and get an expert opinion. Cost you nowt but a little time perhaps. Thumbs Up
http://www.bournemouthlr.co.uk/ If you go through life with your head in the sand....all people will see is an ar5e!!
Post #396927 8th Feb 2015 11:05am
I-Landy
Thanks K9F,
Tomorrow? What time you open from?
Post #396936 8th Feb 2015 11:38am
K9F
Laughing
I wish.....when referring to 'here' I meant the link, not the fact it belongs to me. Not mine, but one I have visited. Turn in by the Macdonalds onto the industrial estate, first right, then left, it's the last unit on the right hand side.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #396937 8th Feb 2015 11:44am
I-Landy
Ha! I thought it was a brave business move, but now that makes more sense. I'll try them. Thanks for the link.
Post #396940 8th Feb 2015 12:00pm
K9F
Let us know how you get on. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #396941 8th Feb 2015 12:01pm
I-Landy
Apparently it's Clutch Slave Cylinder. Gearbox out job is what I've been told. Ouch! 😳
Post #397303 9th Feb 2015 2:52pm
While the box is out, get them to inspect and lubricate the gearbox output adaptor shaft splines. You'll probably also want to consider a new driven plate (even if the old one isn't contaminated with fluid) since they have a very limited life before the springs take on a permanent set.
Post #397316 9th Feb 2015 3:29pm
I-Landy
The garage has suggested a new clutch whilst the box is out. I didnt realise the slave cylinder was such a big job! Got to be done though...
Post #397329 9th Feb 2015 4:17pm
K9F
Can be done at home with the right time, a little help and tooling.....
Be interested to know how much he has quoted as a guideline. There is also AL Services in Poole. You could give them a call for a quote perhaps and see who comes out on top?
Thumbs Up
I don't own or work at this one either...... Rolling with laughter Thumbs Up
http://www.alservices.co.uk/about/ If you go through life with your head in the sand....all people will see is an ar5e!!
Post #397336 9th Feb 2015 4:40pm
It isn't a big job, it just requires removing the gearbox!
I suppose it depends how you define "big" though!
Post #397353 9th Feb 2015 5:19pm
MK
Gearbox and engine oil smell very different so get some engine oil from your engine and compare. Viscositywise is hard to tell. Puma 110" SW
Post #397518 9th Feb 2015 11:49pm
