Home > Maintenance & Modifications > Offroad-Tec |
and people are saying that stickers void your insurance
might be all right in the bush , don't think for the road |
5th Feb 2015 1:57pm |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 |
And who said it would be for the road?
I know theres a lot of defenders on here being used as chelsea tractors that will never be used in anger, but not all of us fall into that category |
5th Feb 2015 2:15pm |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
5th Feb 2015 2:18pm |
no doubt someone would fit them and never go off road!!! |
5th Feb 2015 3:07pm |
Yes that kind of idea. Im pretty sure i have seen some that fit onto cargo tracking thats been fixed to side of vehicle. Looks neater that way. |
5th Feb 2015 3:11pm |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1032 |
Make an ideal for the drinks cabinet!
Click image to enlarge |
5th Feb 2015 4:49pm |
Offroad-Tec Member Since: 28 Jul 2012 Location: Damshagen/ Baltic Sea Posts: 58 |
Hello,
the photo show's a unpainted example. The bracket on the photo isn't fixed at the car - only hanged in the roof gutter. To fix the can you should use 2 belts. There are many openings to fix the belts. There aren't metal fixings because the brackets must be flat if you drive without loading. The brackets can be used for separate fixing systems/ mount plates. Regards - Markus |
8th Feb 2015 8:38am |
wmca Member Since: 15 May 2013 Location: Brisbane Posts: 26 |
Excuse my ignorance, I have read this term before, what is the reference to a �Chelsea Tractor� WMcA Brisbane Australia
Defender 2.4 Puma 2009 �Airbags! The other vehicle is my crumple zone!" |
8th Feb 2015 11:28pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Chelsea tractor = large normally expensive 4x4 used exclusively in an urban situation as a status symbol. Typically on school run or shopping trip. Will not be used as a work horse towing will probably never be driven off Tarmac. Chances are driver does not know width of vehicle, will not know what a low box is or traction control etc.
Brendan |
8th Feb 2015 11:45pm |
Thanks mate, understood now, we may refer to it as �as a Torack Taxi� an up market suburb of Melbourne where $100,000k+ vehicles are used to drop kids of at school. This reply is not intended to upset anybody in AU. WMcA Brisbane Australia
8th Feb 2015 11:55pm |
How do you stop the whole mounting bouncing/swinging about the roof gutter fixing, especially if off road or going over speed bumps? I'm thinking of this effect: Click image to enlarge |
9th Feb 2015 11:02am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5865 |
Now that I like. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
9th Feb 2015 11:08am |
Hi,
the carrier is tested many many kilometers on/ offroad (with 40 kg per bracket). You fix the bracket in the roof gutter and (!) at the body. The original pop rivets must be drilled off. At the same position you can fix the carrier with 2 (1 jerry can) or 4 screws (2 jerry cans). Fot the HD-freaks we have a bracket for the safety devices roll cage (you can fix a spare defender ) Click image to enlarge Click image to enlarge You can trust on this carrier! |
9th Feb 2015 11:43am |
I think this is a very elegant solution along the same lines - it's from Touratech and mounts a 2 litre plastic bottle but could be scaleable:
9th Feb 2015 12:12pm |
