Home > Td5 > TD5 Engine noise
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
TD5 Engine noise
hi folks,
My TD5 defender has a new noise Wink
1) It only occurs when the engine is cold, and not immediately, say 15 secs after start up;
2) Noise disappears within 5 minutes of running the engine;
3) Oil pressure light goes out as per normal within a second or two of start up;
4) Plenty of engine oil in engine and has used only 0.5ltr in 6000 miles;
5) It sounds like its coming from the front left side of the engine (turbo side);
6) Gut feel - I think the noisy component is its belt driven....
Trouble is the noise disappears within 5mins, which suggests bearing and temperature or possibly alternator charging battery??
What are the symptoms of a water pump bearing starting to let go??
No noticeable performance degradation.......
Any thoughts?
I don't have easy access to the internet so cant upload a vid or even monitor this thread closely (sorry and thanks in advance).
Andy
Post #386958 10th Jan 2015 11:44am
bob neville
Might be worth checking all the heat shields are attached and not touching anything.
Before Christmas I parked my TD5 up for the night and all was OK.
Next morning on driving off it sounded like the engine was going to go.
Got it into an Indie for a service and they found one of the shields near the gearbox had moved and was causing the noise.
Not saying this is your problem but it is an easy thing to eliminate.
2013 Defender 90 CSW - sold
Post #386983 10th Jan 2015 12:43pm
ROBBONTHEROCK
Interesting, good suggestion.
My gearbox was replaced in November, much the same time as the new noise developed.......
Might have a crawl under her this avo.
Andy
Post #386985 10th Jan 2015 12:45pm
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
If you think it is belt driven it will do no harm to remove the belt and to run it for a very short while - just a few seconds should be enough to see if the noise has gone or not.
It's a good time then to examine the alternator and waterpump while the belt is off.
Dave
Post #387276 11th Jan 2015 12:17am
ROBBONTHEROCK
Hi folks,
just to follow up on my noisy engine.
drained the oil, no metal in the oil.
Removed the rocker cover - nice shiny metal, nothing abnormal.
Noise still there....
Removed the belt & started up.
Noise disappears............
Have new belt to refit, so will do tonight, also found that the Haynes manual is wrong about the belt tensioner, to slacken the tensioner, you need to rotate the tensioner CCW.
PS, do I really need to remove the viscous fan to refit the belt? If so where can I buy the right tool from?
PPS, found that the two idler pullys next to the PAS pump are noisy / notchy and are possibly contributing to this noise, where can I buy replacements?
Thanks in advance.
Post #395383 3rd Feb 2015 9:42am
It will be the bearing on the belt tensioner, only happens when it's cold. It will eventually get worse. It's a very easy fix and there's lots of 'how to' posts out there.
I did mine when the weather turned colder. Buy genuine or a good pattern part.
There are people who replace the bearing in the tensioner itself, which seems a bit stupid to me!
You can buy the right tool for the fan, I think I improvised somehow, though can't remember how !!
Post #395386 3rd Feb 2015 9:52am
grumpy old git
The idlers are easy to get hold off, most places stock them. Be aware that they are different - often referred to as left and right. The left one has a spacer that fits behind it. They undo as normal. I've just replaced the right hand one on mine, went for genuine and the best price was Island 4x4. Sorry I can't help with part numbers as I'm on my phone.
Post #395387 3rd Feb 2015 9:52am
ROBBONTHEROCK
hi folks,
Thanks, yes left hand and right hand idlers are both notchy and noisy to spin by hand.
Will also replace the tensioner as well.
Where can I get genuine LR belt and associated pulleys (apart from LR)?
What's the part numbers?
I "think" the numbers are:-
LH - ERR6658
RH - ERR6493
Appreciate any advice.
Andy
Post #395423 3rd Feb 2015 1:11pm
mk1collector
Might want to check this too.
http://www.defender2.net/forum/topic34504.html
Ray
Post #395426 3rd Feb 2015 1:25pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #395446 3rd Feb 2015 2:10pm
grumpy old git
Yep, those are the right pulley numbers. The belt is a PQS101490 for -aircon -ace. As I said Island were cheapest for me, and if you're buying all three you'll be over the �50 for free post. No affiliation, just a tight git who googles for prices!
Edit - The fan belt number is for a Td5 Disco - you will need to double check that's what you need Thumbs Up
Post #395459 3rd Feb 2015 3:23pm
ROBBONTHEROCK
Hi folks, great tip thanks.
Have ordered from island 4X4, fingers crossed get them for Friday (or sooner).
Cheers folks - will give an update after the weekend.
Andy
Post #395497 3rd Feb 2015 6:22pm
